Combine satellite/over air antenna
Mr Tony
2,075
8,392
Mankato, MN
try and run 2 cables if you can. I tried the diplexer route and the weaker antenna & sat signals were gone with the diplexer ;)
mr.crane
Iceberg, think you are right, I have a wireless a/b switch remote with the
a/b led in front of the little box. will this work for me. I know its in a
box somewhere in the shed. I did see it about 2 months ago when I
was cleaning.
McGuyver
783
2
Nuclear Testing Grounds
IMO, diplexer qualities vary widely from brand to brand and after trying a couple of brands I found the "Holland" brand to be excellent, no loss of signals for me, I've tried with and without and I always get the same good results with the Hollands. I even run a motor through my Hollands and never a problem. They're very inexpensive so it won't break your wallet to try 'em. I bought 2 for under $5 bucks shipped.
SatelliteAV
6,486
186
Roseville, CA
Every diplexer, no matter the brand, have an insertion loss. The minimum insertion loss is 1.5dB x two diplexers. It is best not to use diplexers if you have the option to run multiple coax cables.
McGuyver
783
2
You're right and the same goes for any switching device but with a fine tuned system and a good receiver, the insertion loss shouldn't be a factor providing the signal strength of the feed is sufficient. The Holland diplexers haven't inhibited any of the feeds on my 16 sat system, I haven't been able to note any problem using them.
carlospr43
967
12
US
Can someone shows us all how can we make the connection of the diplexer?? Also I know we will need an external switch so we can conect the coax from OTA
Thks
McGuyver
783
2
Thks
This is the basic application, no other switch is needed except for any you might be using for the dish itself. Only 2 diplexers are needed to combine the 2 sources.
carlospr43
967
12
US
Thank you so much!!! Looks pretty easy. Let me get the 2 diplexer to give a try!!! Again Thks!!!
P.D.
If you don't matter the pic goes straight to my FTA references book!!!!!
