scoreboard question
RedWings
841
Leesburg, VA
When I turn to a sports channel I'll get a popup that says scoreboard with the red button next to it. If I hit the red button it opens the scoreboard. If try to hit the red button a few minutes later it just makes a bong sound.
Is there a way to get this at anytime?
It should be available all the time on any sports channel. If you hit exit it will disable it. If that happens just switch to a different channel and then back. It will be there.
Another way to reload the ScoreGuide (if "Exit" is pressed) is to pull up the channel guide and select the same channel that you are currently watching. The ScoreGuide will reload then.
you can also turn off that "bong" in the menu settings under audio. Says effects and can have it be low, medium, loud or off :)
