MoCA Strength Bars (Diagnostics ---> System Info)
I'm not sure what it indicates. When I was having trouble streaming consistently in one of my rooms the indicator was green. After I messed with my wiring and got the room working properly, it turned yellow.
Just got installed yesterday. Havent played with it enough yet, but getting "kangaroo" watermark on lower right of screen. "Cancel" makes it go away for awhile. Also getting MoCA signal bars on lower right when I was tuned to HBO, ESPN, SiriusXM, etc. Is there a way to turn these indicators off permanently?
Menu, settings, network setup, whole-home, display settings, select "disabled", Save
Here is what I have on the MoCA icon.
Depending on the Quality of the MoCA signal, the signal quality icon
On the
system info screen can be GREEN, YELLOW, RED or GRAY
To Check the MoCA signal:
1. Use a JOEY
2. Make sure your watching LIVE TV
3. Press the YELLOW Button on the Remote
4. Select " Diagnotics"
5. Select "System Info"
6. Look at BOX "C"
<If BOX "C" is Not GREEN, check the cabling and connectors>
