DBS6000HD
OMG it works.
Still has some bugs but it's a start.
So now its ALI Vs Fujitsu. Who will win time will tell. I think I am going for the trifecta all three 6000, rs-1933 and micro. In the end i think it will come down to who has their Source code to cut out the china mfr and develop in the good old United States.
You have the DBS6000 more the a week now , no review ? all we read is a bunch of B/S
As noted above, a software update came out last night taking care of some of the bugs in the software such as shifting to PAL! Also CONUS USA birds were added.
Lol. Hard to do a review with a B/S firmware. I was planning on doing one today.
No soup for you. :)
Introduction:
The DBS6000HD is the newest High Definition PVR Ready from DMS.
Retail Cost
$169
Features:
  • HD PVR Ready
  • Fujitsu H60 FTA + USB + PVR + MULTI CAs+ LAN(CC CAM, NEW CAMD, MG CAMD SUPPORTED)
  • Fully compliant with the DVB-S2 digital TV reception standards
  • Support DVB-S/S2 digital TV signal modulated in QPSK/8PSK
  • Input frequency range of 950MHz-2150MHz
  • Support HDTV/SDTV MPEG-2/MPEG-4/H.264 decoding Video format and 1080i,720p,576p,480p
  • USB2.0 high speed OTG controller (PVR/ Media Play/SW upgrade)
  • Ethernet 10/100 Base-T MAC interface build-in
  • HDMI/CVBS/YPbPr output
  • Support CA (CAS embedded option)
  • Dolby digital encoded bi-stream output via S/PDIF
  • DTS encoded bi-stream output via S/PDIF
  • Multi-language OSD (English, German, Arabic, Italian, Spanish, Thai..more…)
  • Multi-Scan Mode (Blind scan, default scan, TP scan)
  • Support 7days EPG, Subtitle, osd teletext
  • Audio language, intelligent graphical user interface design
  • Support DiSEqC1.0/ DiSEqC1.1/DiSEqC1.2
  • Friendly channel selection, by sort/index/find/log
  • Favorite Channel edit, parental lock
  • Variable aspect ratio(4:3,16:9)4:3 Pan&Scan Letter Box modes
  • Support USB PVR, MP3,JPG photo playback
  • Support MP3,WMA, WAV format multimedia music file
  • Support JPG, BMP, PNG format multimedia picture file
  • Photo slideshow while playing MP3
  • Support MKV, FLV, avi, dat, mpg, mpeg, ts, trp, tp, m2ts, vob, mp4, mkv, motion jpeg format
  • Manual PID/Satellite and transponder/web search
  • Transponder parameters upgraded by internet
  • Sorts: Alphabetical, satellite, free/pay, parental locks, transponder, more
  • Dimension: 230 (W) x 140 (D) x 39 (H) mm
  • Weight: 1.5 Kg (Net)
Includes:
  • DBS6000HD Receiver
  • Remote Control and Batteries
  • Composite Cable
  • Operators Manual
Technical Details:
Tuner & Channel Decoder
  • DVB-S2 Standard (ETSI EN 302 307)
  • Input Frequency 950~2150MHz
  • Connector F Type
  • Input Impedance 75?
  • Input Level -25~-65dBm
  • LNB Power 13/18 V
  • LNB Control 22KHz
  • DiSEqC Ver 1.0/1.1/1.2/USALS
  • Demodulation QPSK, 8PSK
  • Symbol Rate 2~45Mbaud (SCPC/MCPC)
MPEG Transport Stream A/V Decoding
  • Transport Stream: H.264(MPEG-4 part 10, MPEG-4/AVC and H26L)
  • Profile Level: MPEG-II ISO/IEC 13818-2/11172-2, MPEG-4/AVC MP@L4, MPEG-II MP@HL
  • Input Rate: Max. 80Mbit/s
  • Video Formats: 4:3 Letter Box, 4:3 PanScan, 16 : 9
  • V Resolution: 720x576i, 720x576p, 720x480i, 720x480p, 1280x720p, 1920x1080i, 1920x1080p (supports only HDMI)
  • Audio Decoding: Dolby Digital, MPEG-1 Layer 1,2 and 3
  • Audio Mode: Stereo/Joint stereo/Mono, Dolby Digital bitstream
  • Sampling Rate: 32KHz, 44.1KHz and 48KHz(According to input)
  • Transport Stream MPEG-2 ISO/IEC 13818-1
  • MPEG Profile Level MPEG-2 MP@HL, MPEG-4 MP@L4 H.264
  • Aspect Ratio 4:3, 16:9
  • Video Resolution 1080i 50/60Hz, 720p 50/60Hz, 576p 50Hz,576i (PAL), 480p 60Hz, 480i (NTSC)
  • Audio Decoding MPEG1 layer I, MPEG1 layer II, MPEG1 layer III, MPEG2, AC3
  • Audio Mode Stereo/MONO/Left/Right
Main System
  • Main Processor: Fujitsu H60
  • Flash-ROM : N/A
  • SDRAM : 1024 Mbytes
  • EEPROM : N/A
Audio / Video & Data IN/OUT
  • RCA with CVBS
  • HDMI (HDCP)
  • YPbPr with CVBS
  • Left/Right analog audio output (RCA)
  • Digital audio output (Coaxial)
Front Panel
  • Slot: 1 Smartcard slot
  • 2 USB 2.0 Host port
  • Display: 3 Digit
  • Buttons: 1 Button (Power)
Power Supply
  • Input Voltage: AC 100 ~ 240V, 50/60Hz
  • Power Consumption: Max. 28W
  • Standby Power: Max. 1W
Physical Specification
  • 230 (W) x140 (D) x39 (H) mm
  • Operating Temp.: 0°C to +50°C
My review will continue...
First Impression:
My first impression of the dbs6000hd is the unit is very small and has the FCC logo.
Remote Control:
The remote control is just a normal small generic.
Setup:
My unit came in PAL for some reason. After hooking up the Composite video I was able to switch back to NTSC.
Satellite Setup:
Started by adding the American sat list file from the dms website. It does not have AMC 21 (125) So I added it and selected the parameters for the satellite.
Blind Scan:
I want my pbs so I started the blind scan and noticed it is not super fast but it sure is not slow either. I am very happy with the blind scan on this STB.
1st video channel:
Well to be honest everything was great until I went to watch the pbs hd channel and then all hell broke out. I had to reboot the STB and could only watch SD.:confused:
Come to find out the box was going into pal mode when switched to an HD channel.
Firmware:
The great news is dms came out with a new firmware to fix that issue and other issues. :) I installed it right away.
Here is the pdf datasheet on the H60.
  • MB86H60_FactSheet__FINAL1208.pdf
My only suggestion on your review is to use a photo resizer on your pictures as it takes a while to download them now and someone with dialup is going to have a real problem, I always resize my pictures to 800x600 size.
With the MicroHD comming out and with a lower price, OpenBox S10 going for $75 with free shipping on ebay.
The DBS6000 is over priced.
From what I can see it's probable is going to be the best option out there since the MicroHD doesn't come with the needed outputs for all people and S10 has a questionable history.
What about the closed caption through hdmi? works fine?
Bump this question as I am also curious! Also, CC pass through on component /composite? TBN on 97 Ku or on G14 C-band is a known 24/7 channel with CC.
Also, does it only do QPSK and 8PSK? Does it do H8PSK or 16APSK? These are questions that customers will ask when shopping. Thanks!
My Three Sons Marathon / Passing of Don Grady
Montana PBS Very Strong.
