Hmm let me check the uplink pc and see if its stuck.
They like you.But why did my signal go up for WWOR HD if they were making it a tighter Spot beam doesn't make since to me.
Starts with 18 . 17 is Conus only.Pretty sure all tps 17 thru 32 are now the spots for new bird.
OK I go w/ that as there is signal on 17 and it doesn't switch to spot when I go there. Sure takes a long time for a lock on those tps now. I only see 24 & 32 and it takes 30 secs or more for those to show up.Starts with 18 . 17 is Conus only.
You mean the areas they are for. We know where they are coming from (61.5) just not to whom that they belong to yet.Yes it takes longer for me also to let you know. Still would like to know where the other beams are coming from I guess we will know as the weeks go on.
So the spot maps on SatMaps are not accurate?They like you.![]()
It's a stronger signal bird. The spot you are on may not be centered over NYC. Over time we will see new graphics for where the spots are actually hitting.
