Ok, here’s a(nother) stupid question.
I got confused (as usual) about hooking up a 3x4 switch..
I knew that the H & V go to either the 18v or the 13v. Or maybe the other way around.
I tried to google it and found a flood of nonsense I couldn’t wade through.
I also found a section in here about switches but I found the part about the 3x4 switches to be, a bit unclear or uncertain, for me. My brain didn’t seem to grasp it.
Anyway, I took a best guess at it and it SEEMED to work. I put the H/V LNB on my motorized dish then I put the 3x4 on it to combine them into one wire for my MicroHD.
I went back inside and I had TV again on the MicroHD. Cool beans…
So yesterday evening I decided to see if I could also tap it off into my PC so I ran a wire from a port on the 3x4 over to a spare port on the 1x8 feeding my PC.
I check the MHD and it was fine. Then I add 83w to the PC, setup the LO and the port of the 1x8 it is on and hit scan. Nothing..![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I scanned like 8 times and nothing. Bah.. So I quit the PC and went back to watching Dish Network nonsense the rest of the night.
Later on when I went to bed I wanted to watch the MHD but to my dismay, there was still no signal, AGAIN, on it. Arrrrrrrgh!!!!!!!!
I gave up and again watched Dish..
Then today I was outside getting ready for some really bad weather that is headed our way and I decided I wanted to try once again to get it working on two systems.
I went outside and put my meter on the 3x4 and PBJ came right in just fine. I went inside and tried scanning on the PC again and still nothing..
On the MHD I had now lost ALL ku channels. Nothing was working except C-band.
I went back outside and found there was now no signal going to my meter.
Back inside and more scanning and still nothing. Then I changed channels on the PC and watched OTA on it while I contemplated this stupidness.
All of a sudden I heard the TV in my bedroom blaring a cartoon. I go in and check and the signal is there and strong.
So I try again and nothing on the PC. I go back outside and again there’s no signal on the meter.
Back inside and there’s again nothing at all on ku.
Then I thought about flipping the polarity on the PC. I set it to 11735/4440 and VERTICAL and BAM! It scanned it.
I check the MHD and it’s still working too.
What I don’t understand it why the MHD which is set to 11735/4440 HORIZONTAL works fine but the PC has to be set to vertical? I changed nothing at all on the MHD and it works until I try to set the PC to work the same way!
When I set the PC to V and the MHD to H, both work fine at the same time.
What am I doing wrong? I assume I have the wires backwards between the LNB and the 3x4 but if that’s so, why does the MHD work but not the PC?
I set them up as Horizontal to 18v and Vertical to 13v..
For now I have the polarity on the PC set wrong, to vertical. It’s raining and tomorrow and Saturday it’s supposed to flood so I won’t be able to mess with it for 4-5 days, maybe more if it’s as bad as they say.
Is there any potential damage I could do with things wired like this? Should I not use it for now?
?Thanks…![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
?Thanks…
