Question about splitters for use with 2 swm64's
info411man
37
Columbus, KS
Sorry title should have referred to Swm16 not Swm64
Checking on SolidSignal it shows http://www.solidsignal.com/pview.asp?p=SP2WAPHL&d=Skywalker-2-way-Splitter-for-Off-air-and-Satellite-signals-(SKY23302D as the splitters to use. My local Lowes has these splitters http://www.lowes.com/webapp/wcs/sto...&catalogId=10051&productId=3583098&cId=detail which I could pick up tomorrow instead of waiting for them to be shipped from SolidSignal. My question is are the ones at Lowes equivalent to the ones at SolidSignal.
Thanks for your help,
Frank
Need more info, what D* set up are you working with ?
SWM,
What recvrs are you using in the set up and what are you trying to accomplish ?
How can you have a SWM set up without having the required splitters already ?
SWM,
I currently have:
Slimline 5
Swm16
hr34
hr21 x4
hr20
h21
I will be adding another Swm16 with HR44 & client, it is a second acct so I will not be using multi-room between existing receivers and new ones.
I am going off page 7-8 from this document: http://forums.solidsignal.com/showthread.php/336-WHITE-PAPER-More-than-16-tuners-in-the-home
I currently have:
Slimline 5
Swm16
hr34
hr21 x4
hr20
h21
You say this is a separate account ?
How much is on THAT system ?
Also, as far as Solid Signal, they usually can get your stuff within a few days.
So you are going to have 2 Genies on separate accounts,but you want the ability for them to see each other & to operate together under a combined whole home dvr set up? Are you also duplicating the programming package you subscribe to under both accounts? That is a lot of coin if I ever tried that,A LOT OF COIN.
This is what I was wondering as well.
