Hi all,
Can I please get your input? the below image is of my current LNB, ive had it for over 20 years and would like to know if its worthwhile to replace it with one of two options I came across.
CURRENT LNB
from what I can make out from whats left of the tag, my current LNB is a California Amplifier Slimline II Model C31012. I cannot make out the gain nor the noise numbers, which is why I need to know if any of these two options is better than the one I currently have.
OPTION 1:
LNB PANSAT
Mod: PC-9500W
Input Frequency: 3.4 ~ 4.2 GHz.
Output Frequency: 950 ~ 1750 MHz.
L.O. Frequency: 5150 + 2MHz.
Noise Temp. (@ + 25'C): 17 to 25'K Max.
Input VSWR: 2.5 : 1 Typ.
Image Rejection: 40 dBc Min.
Conversion Gain: 65 dB Typ.
Output VSWR: 2 : 1 Typ.
Gain Flatness: 6 dBp-p Max.
Gain Ripple(Per Channel): +/- 0.75 dB Max.
1dB Gain Compression Point: +5 dBm Max.
Output Impedance: 75 Ohms.
Leakage(@ Input Port): -60 dBm Max.
Phase Noise: -80 dBc/Hz(@ 10KHz), -95 dBc/Hz(@ 100KHz), -110 dBc/Hz(@ 1 MHz).
OPTION 2:
LNB CHAPARRAL
Specifications:
Part Number 11-7250-1
Input Frequency 3.4 – 4.2 GHz
Output frequency 950 – 1750 MHz
Output Connector Type “F” Female Connector
Conversion Gain 65 dB typical
Noise Figure 20 dB
LO frequency 5.15 GHz
LO stability +/- 2.5 MHz
Weight 200g
In your experience do you think im better served getting one of these two options rather than sticking with the one I have? FYI the price they are asking is pretty much the same for the chaparral and the pansat
Thanks for the input
CURRENT LNB
![1601280614370104.jpg](http://www.hostpic.org/images/1601280614370104.jpg)
OPTION 1:
LNB PANSAT
Mod: PC-9500W
OPTION 2:
LNB CHAPARRAL
Specifications:
Noise Figure 20 dB
Weight 200g
