Is it possible
SPower
64
34
Fallon, NV
To realign my dtv dish on the house to the dish network satellites (110, 119, 129)? The dtv dish is HD with 3 lnb's.
Thanks.....
DISH Support
OFFICIAL DISH SUPPORT
Staff member
DISH DIRT TEAM!
Jun 6, 2019
743
788
Hey, SPower! Just to be clear on what you're asking, are you wanting to get a DIRECTV dish or DISH Network dish aligned?
SPower
64
34
Fallon, NV
I have dish account, am using a portable dish because I travel all the time but when at home base would like to use a "permanent" dish. There is a dtv permanent dish already installed on the house, can I realign it to use with dish satellites?
JSheridan
8,899
10,028
USA
Nope, sorry it won't work. Dish 1000.2 Western Arc dishes are readily available and would work for you.
What kind of receiver do you have?
HipKat
17,393
32,912
Pekin, IL
New ones come in pieces, worried about putting it all together...
On another note, I was also thinking I could probably use the same "mast" after I pull the dtv dish off of it right?
It comes in 3 pieces. The Feed Arm/Skew Plate Assembly. The Reflector. The LNBF Bracket/Yolk plus a bag of bolts. They only fit one way
Claude Greiner
13,213
3,776
Detroit - The Paris of the Midwest
Thanks.....
It’s possible, but the LNB’s would need to be changed. By the time you messed with it, tried to adapt the dish LNB’s it’s cheaper to buy dish network dish.
JSheridan
8,899
10,028
USA
Yes and no on the mast. If it's an old DirecTV Phase 3 dish then the mast might be the same size. If it's a bigger mast then you can get a pole adapter to downsize it.
TheKrell
A mighty and noble race originating on Altair IV.
38,819
46,481
Fairfax, VA
Mast sizes are different.
Really? About 15 years ago, I could have sworn I reused a DTV mast. Maybe they used different sized masts depending upon which DTV dish it is. The OP hasn't said.
Dished Off
Jun 14, 2016
24
19
Scranton
Thanks.....
It would most likely require a Western Arc dish, and would likely cause you to lose access to your locals depending on where you are.
