LocutusOfBorg
Free speech is more important than your feelings
The glass is not half empty...
For a few hundred dollars, the Dr. HD 1000S and 500 combo models have spectrum analyzers that puts the XR-3 to shame. 30fps!
Need to look at a range of the spectrum, not a tiny slice.
You want to find solutions or keep swinging at the piñata?
Something isn't set to the right settings, or assembled correctly. Take a LOT of photos of the dish & mount, and post them. Maybe we can catch it.
Just quickly scanning through your pics, it seems obvious that your feed scalar is NOT parallel to the dish, and is NOT pointing at the center. That alone might explain most of your issues. If those are not right, all your compensating with other adjustments is a total loss.
That is indeed strange.. Either your true geographic south is not where you think it is (you might want to verify what the compass is saying with landmarks you can see and google maps). DO NOT rely on the compass in a phone. Or maybe the geometry of the dish is off. Did you do a string test? Also you might want to verify the centering of the feed with a tape measure, not just visually.dishpointer.com says the elevation should be 41.6 for 103.0W which would be my "true south" sat at azimuth 179.0 true. My home longitude is 103.633W. KTI manual says to set elevation to 42.7 for true south. I set the declination for 5.9 per the KTI manual. 103.0W would be slightly east for me. I must be doing something wrong because the antenna is pointing west of true south for 103.0W instead of east. When I try to search east of center I can't get anything for 103.0W. I'll have to see if I can find a friend to check my initial true south setup.
To determine if the feedhorn is centered, measure from several points around the reflector rim to the center of the feedhorn opening. If all measurements are equal, the feedhorn is centered. The simplest way to measure for centering is to punch a hole in the center of a throat cap, knot a string and pass through the hole. Insert the cap into the feedhorn throat. Use the length of the string to measure around the rim of the dish instead of fighting a measuring tape...
A laser pointer device will not determine if the feedhorn is centered on the reflector. The pointer device assists in making sure the feedhorn and scalar are pointed into the center of the reflector.
Something looks a little funky?
The photo of your dish pointing straight up. Is your skew 0 reference on the lnb straight up too?
