Can't Get 110
WesTexican
Oct 25, 2022
6
11
Texas
I have a 1000.2. Pole is plumb. Have the angles set for my zip code. Started sweep from almost due East and adjusted & peaked it on first signal. (just have a simple analog satellite finder). Couldn't get 110 but 119 and 129 are coming in good. Moved to different location 20' away and started all over again and got the same result. Ordered and installed another LNBF and again got the same result. Run check switch and not finding 110 at all. What am I missing or what else could I try?
Thanks!
rvvaquero
3,318
4,517
SE Texas
Thanks!
You're pointed about 10 degrees too far west.
NYDutch
7,127
12,722
Where our wheels go
Tried moving 10* back to the East and nothing. Went way East and started back very slowly. Ended up where I started to get any signal and still no 110. I’m still missing something.
Any trees in the way? Have you tried one of the free augmented reality satellite aiming apps to make sure?
NYDutch
7,127
12,722
Where our wheels go
No trees, buildings or any obstructions. Haven’t tried any apps.
Was really hoping that it was just something simple that I’ve been overlooking.
I’ve watched a ton of videos. It looks so easy on the internet! LOL!
The apps make it even easier. Make sure you're using the side plates on the mount to align the azimuth, not the LNB arm.
Jim5506
8,138
3,499
Slaton, Texas
Cover the outer 2 lnb's and find 119 with only the center lnb available. If your skew and elevation are buy the book 110 should be there. There may have to be some very minor elevation tweaking to get max signal but don't mess with the skew unless you already have - in that case you need to reset skew to the dish book value for your zip code.
Be sure to run a check switch after initial alignment or the database in the receiver will not have the correct data for all three sats available.
If all this fails, it may be time to call Dish for a tech visit.
WesTexican
Oct 25, 2022
6
11
Texas
Thanks NYDutch!
No obstructions but does look like it’s off. Centered camera lens on LNB arm and took this shot. Looks off?
Guess my elevation is off is why I’m going too far West to get signal. Correct?
NYDutch
7,127
12,722
Where our wheels go
Thanks NYDutch!
No obstructions but does look like it’s off. Centered camera lens on LNB arm and took this shot. Looks off?View attachment 159082
It looks that way. Don't forget you may need to tweak the elevation a little to optimize all three signals. I suggest snugging the mount clamp up until you can just rotate for alignment. That helps eliminate any drooping from excess play that throws off the elevation a little.
WesTexican
Oct 25, 2022
6
11
Texas
It worked! It’s all good now. Thanks for all your help!
It is really easy as long as you do the prep right and double check the easy stuff! LOL!
