Good evening everyone! After much research and struggle, I've finally been told of a way to get the Gemini C71KW-400 boxes for STREAM use to be used on satellite, perfectly fine. This method was originally told to me by user @Good4U on the DIRECTV Community Forums, so shoutout to him.
1. FACTORY Reset your Gemini
Internet box by pressing the red reset button for 20 seconds.
2. When your Gemini with DIRECTV STREAM firmware is finished with this, it will boot up to where you press the 'OK' button followed by "BACKWARDS" and "FORWARD" BUTTONS. During this process, ensure that your Gemini is NOT plugged into ethernet (no internet connectivity at all).
4. Once you get to the section where you put in your WiFi password, press 2326 on the remote. This should restart your Gemini with DIRECTV STREAM firmware.
5. Once it is booted back up, follow the same remote pairing procedure as in the beginning of step 2. Then, instead of being greeted with the Internet WiFi settings, you should be brought to 'ADD YOUR GEMINI'.
6. You have officially converted your DIRECTV STREAM Gemini box to a DIRECTV SATELLITE Gemini receiver.
I am not aware on a way to convert a DIRECTV SATELLITE box to DIRECTV STREAM yet. So, if you follow this method, there is NO TURNING BACK!!
Thank you for reading this. Feel free to let me know if you have any questions below. Good luck!
