What Next????????????
jubes23
Feb 2, 2007
10
Just purchased a Pkillips PHDTVUI Silver Sensor Classic, I want to hook it up to My fathers T.v. Toshiba ReGZA LCD 42 inches. What do I do next? Does he need a HD box to recieve the signal, or can I just connect the Antenna to the T.V.?
navychop
60,035
27,322
Northern VA
Yes, if that TV has an ATSC (digital) tuner. But I don't think it does. You'll need an aftermarket ATSC tuner.
jubes23
Feb 2, 2007
10
Zip code is 56013, I am sure it is pointing in the right direction, although There is a brick fireplace in the way. Model # is 42hl196. If I need an after market tuner how much money are we talkin?
jubes23
Feb 2, 2007
10
According to Amazon.com . While it has a CableCARD slot and built-in QAM digital cable tuner, it lacks an ATSC tuner that would bring in terrestrial or over-the-air HDTV signals.
damaged
2,605
South of Heaven
hmmm, the way the below site words it, it sounds like it would:
http://www.dtvcity.com/toshiba-lcd/toshiba-42hl196.php
"* ATSC/NTSC/QAM Digital Television Tuner"
As does msn:
http://shopping.msn.com/specs/shp/?itemId=611716130
"TV Tuner 1x analog/digital combo"
"Digital TV Tuner QAM, ATSC DTV"
charper1
Bourbon Tester
18,442
6
I'm Nationwide
Well CBS is at 320° and 27m and @ 110° and 9m via a repeater that likely does not pass along digital (not 100% sure). ABC, FOX and PBS are also on that same repeater location. NBC appears to be on another repeater location. The PBS digital is showing to be at 193° and 60m. I am betting that you are going to need more than that antenna to get any quality results as it will likely not acheive 60m to reach that actual IA market and is also highly directional as well and his signals are scattered all over the place. If those repeaters do pass along digital then you may have some luck aimed at around 100°. I attached your zip code results from antennawb. They are ugly.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,803
17,749
Cheshire CT
charper1
Bourbon Tester
18,442
6
I'm Nationwide
Thats just odd & bad marketing. They need to list the installed tuners in the "Key Features" or "Detailed Specs" why would/should anyone have to hunt for that needed info. Thanks for catching that..
lunkie
192
Gotta agree with that. Maybe they figure it being a 1080p set they don't have to tell ya. It's just dumb.
charper1
Bourbon Tester
18,442
6
I'm Nationwide
So now the OP is just back being in a badly laid out DMA for OTA reception and having an OK, but not great antenna, and likely not what he needs. Does anyone know if repeaters pass digital?
