129 and 118.7
nsaspook
356
Fairview, Oregon
I have a 4 SAT/SW64 setup for 110/119/148/121 now. Subbed to OLD HD pack and Viva Pinoy Pack on 121. Have two 811's and two 3900 receivers. I installed a 1000.2 and plan to upgrade the receivers to something mpeg4 but want to receive the Viva pack on 118.7. Is there a stand-alone dish for 118.7 that can connect to the 1000.2 port?
If you have a Super dish (121) get a dish 500+/1000+ LNB assy (118/119) and put on superdish.
You will need to upgrade from the old 811, all this is DP
If you'll find special adapter - the 1K.2 arm is too small for hold + type LNBF.
You can use 1m (30"+) FTA dish for the combo.
Other issue for new config is 148W - as 5th signal, there is no easy way to connect 5 sats to multiple receivers. Also recheck your switch - SW64 is legacy switch for THREE sats.
It's SW21 +SW64 combo "SW21 4-SAT" There is logic in most receivers for it but it's not the most reliable setup.
attachment.php
I have moved the 105 to 121.
That's important details when you describe your setup. Don't omit it.
We have a deal with HW ans SW what required correct definitions.
Also describing in detail your proposal will cut our guessing and your waiting time.
Getting Jealous of Directv?
Dish DVR package - Can I upgrade?
