721 Update
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,811
26,554
Newington, CT
Sorry I haven't posted pictures tonight as planned, I will try to do it tommorow.
I DO have some good news about the 721, I am told that the update WILL (I repeat WILL) got out before the end of the month. (Thats this month, September, 2003) :D
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,811
26,554
Newington, CT
Yeah I know but they have to get it out this month for the SuperDish rollout. :)
It is really good and stable software!
I do believe you guys are really going to like it!
Bill R
364
I have heard the same thing that Scott posted. "The 721 software update will be released before the end of September unless some last minute bugs are discovered".
ken
296
Since the lack of a triple conflict screen is a BUG and should have been part of the first update, I consider the weather page the only real upgrade. This being the case I find it funny that everyone thinks DISH is doing us a favor. This is what should have been part of the original software. It's odd that DISH is still fooling itself into thinking they have good software geeks on staff.
G
Guest
Guest
Maybe the reason why they stopped us from the update last month was so Dish could include the super dish in the dish pointing screen. After all the 301 and the 508s all got this software update so it makes sense to include the 721 with this also.
G
Guest
Guest
Scott,
What exactly betas version you have ? AVQT ?
mgs24
41
Discrete Codes
Scott, Do you know if the Beta Version your test includes the Discrete power codes?
Unthinkable
205
Scott G,
Any idea if the new software update will correct the current problem where a switch check fails to detect all 3 satellites if you have 2 SW21's, 1 Dish 500 pointed at 110 and 119 and 1 Dish 500 pointed at 61.5 for example? When I first installed my 721 it worked absolutely perfect with this configuration, but it was quickly ended by the latest software revision. Same switch and legacy lnb configuration powers two 501's with no issues as well.
Ronster
Sep 11, 2003
22
Dish should send the 721 update out today due to Hurricane Isabel possibly effecting many receivers from getting the download Thursday or Friday.
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,811
26,554
Newington, CT
Unthinkable, I don't have an answer for you on that, I have a SW-64 so I can only report on what I tested.
The new Check Switch Screen seems to be a modern miracle, its SO FAST!!!!!!!!
Stargazer
16,567
340
Western WV
So the new check switch for legacy switches is a lot faster than the old lgacy check switch? I know that the DishPro check switch is already very fast compared to the current legacy check switch.
G
Guest
Guest
Scott,
May be you missed my question ?
Could you tell us what exactly version you testing ?
Just provide the numbers from System Info screen, please.
G
Guest
Guest
I think it's too late worried about that - as we saw ppl testing different versions already.
I heard DVB satellite cards (PCI) could see wich versions spooling for each model.
Probably yours is AXAT. Right ?
721 Two Tuner -- How do you use it?
SuperDish spec sheet out yet?
