Any Way To Add Ntsc Analog Channel 3 To Atsc On Coax ?
DRCars
329
64
Southern USA
I supply my neighbor with TV signal from my antenna via a distribution amp and 200 ft. RG 6 cable (he can't manage to get all the channels that I can). Sometimes he also enjoys watching things that I am watching on my BUD satellite system. To do that I send the satellite composite signal to a VCR, hook his coax to it, and use the VCR's modulator to send him an SD NTSC feed. Sometimes I forget to hook him back up to the TV signal.:rollingeyes
Is there any way to add that signal (Ch 3) to the TV antenna signal without messing it up?
I think I tried a combiner and the results were terribly bad.
DRCars
boba
11,350
1,035
Dorchester, TX.
The most common method is use a Channel 3/4 modulator and a 2 way splitter in reverse as a combiner. The hard part is what channels (actual) are in use by local broadcasters If you were to have a 35-1 channel that actually broadcast on Channel 4 that would kill the combiner idea.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,796
17,739
Cheshire CT
Doesn't the FCC require that either 3 or 4 be unused in every market?
DRCars
329
64
Southern USA
I think so. Anyway the lowest channel in use in my area is RF channel 7.
I recall trying the reversed splitter (as combiner) and something was amiss. Since that is what is being suggested I guess I could try it again in case I SNAFUed something when I tried it before.
Edit: Guess I was right, I must have SNAFUed something when I tried it before. It seems to work just fine now.
Thanks for affirming it should work....It does.
DRCars
Mr Tony
2,054
8,297
Mankato, MN
They still make NTSC channel 3 combiners. Check Ebay
can combine ASTC and channel 3 into one cable with no signal loss
