This is one of those little quirks that can make the CS8000 frustrating to work with.
Added a 4x1 switch to the system and added 2 lines. Before hand I had one cable coming in to the reciever that was hooked to a 4x4 multiswitch.
22k off was G4/G16
22k on was G10
So I added a line for Hispasat and one from the motorized (the motorized line is a slave). Hooked it up and only port 1 works
so I try a different switch. (yes I turned off the reciever on the back with the switch) and still doesn't work. Hook the Hispasat line up directly and it works. So I hooked it back to the switch
port 1 is the 4x4 multiswitch and it works on all
port 2 is Hispasat and need t turn 22k on (the dish is set up that way)
port 3 is motorized
So I thought the LNB LO was wrong so I changed it off 10750 to 10000 and went back to 10750 and BAM...signal
Since I havent used a Diseqc with the Coolsat 8000 before this must be one of those quirks. After I install a switch, on all ports but port 1 I need to go to that satellite, switch the LNB off 10750 and then back and it works. Once the switch is installed and that is done it works fine as I switched between G4, G10, Hispasat and the motorized (it was on AMC6 at the time).
so if you have a DIseqc to a CS8000 and it doesn't work...change the LO and then change it back and that shoudl do the trick![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
22k off was G4/G16
22k on was G10
port 3 is motorized
