no there there just weak. others having problems also. talked about here
http://www.satelliteguys.us/xen/threads/kbrk-no-signal.361951/
I was wondering what was going on. A few months ago, I had a good signal on these channels, and over time, they progressively got worse, but even then, I had a good signal on these channels on SES-1 so I didn't think much about it. Now, I can't get enough signal on this satellite to lock MeTV 1&2 SD, and barely enough to lock MeTV HD, about 52% on the signal quality. Like some others in here, I am having audio stutter on Laff, Grit and the Buzzr, channel.
My wife and I sat down last night and weighed the issue and decided to hook up our old receivers, the HDVR 3500's. Of course we lost H&I, Decades and Movies, but we were able to gain Laff and Grit on Galaxy 19, which we like just as well as the others and there's no stutter in the audio. For some reason, I had to manually add Grit and Laff because even after adding one, the receiver would not find the others during a scan of that transponder. In fact, it deleted the other, so I re-entered them again and it worked with one little hitch.
When I go to one or the other of these channels, it will change channels showing the other channels information, but it failed to switch to the other channel. If I go to a different channel and back to that one, it will work. I tried to enter the transponder, symbol rate and polarity. When I tried to save it, it came up with a transponder conflict error code, even though that transponder isn't in the list. I'm going to try adding some more of the channels tonight and see what happens. There are two more of those channels, I'd like to get working if possible, but if not, we'll be satisfied with the two we have. They were stuttering bad on the Freesat V7 receiver, so it's a plus we can watch them now.
