editing in a sattelite?
edit a satellite or add?
adding a satellite
install---dish setting
click "ok" where satellite is and scroll to bottom. There should be a couple extra sats that say "0.0E"
-press red button to rename then press OK
-enter in all the LNB info/switch info then exit out
-go into manual scan and enter the TP info and exit out (save first)
-go into motorized to set up the motorized. Select USALS and scroll down to "Sat degree" and enter in the sat location as 125.0. Where it says "E" press OK button to make it change to W and save. If you use Diseqc 1.2 you can change from USALS to Diseqc 1.2 to move the dish
It is cumbersome adding a sat but it works :)
To edit a existing sat, just go into dish setting, select satellite, press red button and rename
There are 2 channels that are not AC3
Montana PBS (12103 V 4340) and Montana Legislature (11958 H symbol rate escapes me right now)
12180 is a very strong transponder
Intelsat 9 at 58.0°W - Receivable in MN?
