External hard drive
lynxville
Aug 20, 2012
12
wisconsin
What would be an easy to use and not to expensive hard drive to back up my recordings, so if the Hopper dies I still have my recorded shows and movies?
boba
11,350
1,035
Dorchester, TX.
The answer is how much are you willing to spend, do you want to order from the internet or buy locally. The smaller the capacity the lower the price, do you want to back up everything on the internal hard drive or just selected programs.
fredp
623
112
Williston, Vermont
Just to be clear you cant make a copy of your recordings. You can only transfer. Recordings, selected or all are only on the EHD or the Hopper. The size can be anywhere up to 2TBs. As Boba stated its how much you want to spend. A requirement though is that they must have their own power source, not USB powered. As to what make, just search the forum as their are gazillions of recommendations here.:)
KAB
21,742
5,230
Fishers, IN
Most folks around here use WD. Reliable, and usually just as good a price as any others. Seagates used to be notorious for their sleep modes not "waking up". Not sure if it was ever corrected, but I would still stay away from them.
jerryez
4,750
1,301
Pensacola,FL
I use a 1tb WD my Book external hard drive. I have 80 movies on it and still have 416gb available for less than $100.
sethwell
1,611
58
Booneville, AR
I use a hot swap dock and have a couple HDDs that I can swap around. I put a dock at each hopper and can move a drive easily. Also have drive cases to store the unused drives.
I like the dock because if one fails then I just replace it and don't have to break into the enclosure or take it apart. YMMV
I use WD drives.
Tecmo SB Guy
398
74
About Seagate, if I may ask, what else is wrong with them besides the sleep mode?
I've had a 2 TB WD MyBook for a little over 2 years myself and it works great. But I always thought other than the sleep mode problem that Western Digital and Seagate were pretty much equal.
Teehar
8,395
242
WNC
Just like the others have already mentioned.WD mybook,and elements,both have been great.
bobsie
95
23
Alpena, MI
Can you elaborate on the "sleep mode" problem with Seagate. I have never heard of it.
KKlare
2,397
14
Los Alamos, NM
The Sleep Problem is that when it goes to sleep, usually after 10s of minutes of no use, it fails to wake up for further use. So power off and on again.
-Ken
Jim5506
8,147
3,510
Slaton, Texas
The "sleep issue" is that the firmware on the drive turns off the spinning motor after a certain amount of idle time, which is easily tripped by EHDs on a Dish DVR, i.e., except for the 221/411 series, the EHD is only used while moving programming to it or when playing a program.
Dish receivers do not have the same capacity to awaken these drives as a PC does, for whatever reason.
Dish could probably add some lines of code that would fix this, but you know Dish, "just because it's broke, don't expect us to fix it".
Tony S
1,502
933
Hills of Eastern CT
I also had a lot of problems with Seagate and Maxtor drives going into sleep mode. Only way to wake them up was to remove and reconnect power to the external HD, and sometimes I also had to unplug and replug the USB connector from the back of the Dish receiver. After a while this got very annoying. For some drives with this problem, there was a program that you could download to turn off sleep mode, but this was a poor solution, and there were many Seagate drives that did not support changing this parameter.
Right out of the box, the WD drives are compatible with the Dish receivers. They go into sleep mode, but the Dish receiver is able to wake them up properly when you want to use them.
