Help With " Moving"
whatchel1
9,098
51
Great High Plains
SD locaLA
I'm thinking of "moving" to Kansas City, MO.
Looks like the locals there are on a ConUS beam on the 129 so shouldn't be a problem there.
Will I lose my current Dish locals (non-HD) if I move, or will the KC locals just be added to the guide?
I guess Dish doesn't check the address to see where its at if a movie theater address will work? My 722 calling dish from its original billing address also is not a problem?
I understand I'd have to change the address again before a service call.
Thanks.
The SD locals for KC are spotbeamed. So you will not get those. You will get your guide info for your OTA's if dish carries them via sat. Sign up for paperless billing then it makes no difference where the bill would go since you will be doing it all on line. When they ask about needing Dish mover just tell them it is already taken care of.
GregE
174
Prospect, KY
I have a 722. If I move to Atlanta, what will my TV2 see? Will it see the Atlanta locals in SD? If not I can split my OTA antenna and run a line to TV2 and then just switch inputs. Just curious.
johnpas73
SatelliteGuys Guru
Jul 25, 2007
140
Indianapolis
How long does it take after talking to CS to get the changes done? I talked to CS about 30 minutes ago, and now my old locals are missing from the map down (ie ABC is no longer 6, etc), but they are still up in the 8500 area. I dont have to new locals, and my OTA HD channels are showing "Digital Service" as the description.
Is this normal? Did I mess something up royally?
digiblur
14,190
4
Louisiana
Do a check switch
digiblur
14,190
4
Louisiana
And where did you move to?
johnpas73
SatelliteGuys Guru
Jul 25, 2007
140
Indianapolis
Ran a check switch. Moved to somewhere in Columbus so I can get Sport Time Ohio for Cavs games. Their locals are carried on 129* T 32 and 21. I get signal on both of these transponders.
tick221
Apr 28, 2006
3
I'm in Southwestern VA near Roanoke and want to "move" to either NOVA or Charlotte but I'm not sure how to read if I'm capable of "moving" to these areas
Any help would be appreciated
johnpas73
SatelliteGuys Guru
Jul 25, 2007
140
Indianapolis
Are you doing this to get HD locals?
If so, you would n eed to have your dish pointed at the 118* satellite, which I dont know if you already do or not. Your other option is to move to Atlanta GA or Nashville TN since they oth have HD locals on CONUS 129* satellite.
tick221
Apr 28, 2006
3
How would I know which bird I'm pointed at?
