Help
tsunshine8
Jan 14, 2007
12
i currently have a dish 500 where i can pick up satellites 110 and 119 at the same time. my problem now is i recently bought a 3rd receiver and f-ed everything up. i bought a dp 34 switch from ebay to hook up all 3 receivers and it does not work i can only pick up the 119 satellite and the 110 says wrong satellite. i tried covering up the 119 and found the 110 but it goes back to the same -it cant find 110. i checked the switch it says 119 odd and even. my other 2 receivers say 61.5 odd and 119 even. i have no idea how to fix this. please help
tsunshine8
Jan 14, 2007
12
its a dishpro dual twin lnb. its not $30 to have a tech come out its $49. i'll take the headach and try to fix it myself than pay the $49 but if push comes to shove then as a last resort i will. i tried using foil to cover the 119 to get the 110 signal and it worked but as soon as i uncover it it goes back to saying wrong satellite on the 110
teachsac
Staff member
HERE TO HELP YOU!
Nov 3, 2005
15,315
1,109
Elk Grove, CA
Take the lines off the back of the receiver, do a switch test to clear the matrix. Hook them back up and run another test and see what you get.
I would unplug the feed from all of the receivers. Run the checkswitch on all of the receivers to clear the matrix. Hook up the receivers one at a time to make sure it works.
Did you move your dish at all?
S~
