HR34/C31 System Test
upsss
529
68
AZ
Can anyone run the "System Test" on the HR34/C31 without a failure? When I run this test I always get "Test failed, Diagnostic code 79860, Playback Errors due to dropped connections...". Directv tells me this is "Normal" with all kinds of BS explanations. I am practically experiencing every problem ever reported here plus more. Yes, I know about resetting & unplugging, it doesn't help!
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
The "dropped connections" error isn't always an error, it reports each time you switch the C31 off as a dropped connection. It's a bug that DirecTV is going to have to fix at some point.
upsss
529
68
AZ
You didn't answer my question and I am tired of people trying to excuse the poor performance of the HR34/C31!
upsss
529
68
AZ
Really, here is the question again.
harshness
18,898
4,066
Salem, OR
You didn't answer my question and I am tried of people trying to excuse the poor performance of the HR34/C31!
Diagnostic tests are typically to identify problems that are extraordinary (defective/failed hardware, corrupt firmware, communications issues). Since the issues you describe aren't particularly extraordinary, it is little wonder that your diagnostic results are inconclusive.
The real problem may be that you didn't wait long enough to adopt the technology.
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
You will almost always get that error when you run the system test...
upsss
529
68
AZ
I am still waiting for a simple answer; can anyone with the Genie (HR34) and a client (C31) run the "System Test" without a failure, yes or no? I am not asking for anyone's opinion why would you fail this test. I have numerous problems with the C31 since day one (~2 months ago) and can never pass this test without "Network Playback Errors ...".
rad
Cutting Edge
Sep 7, 2003
11,454
5,913
Dripping Springs, TX
Unless you leave your C31 powered on for over a week, never turning it off, you will get the network error failure during the self test. As others have said this is a bug in the test and every time you power off (or reset) your C31 it creates a dropped connection error which causes the failure in the test. THIS IS NOT AN OPINION BUT A FACT THAT IT IS A BUG IN CODE.
twizt3dsist3r
2,962
212
Pennsylvania, United States
Yes i can run my system test on my genie with no errors.
But only with no other clients or receivers connected to trigger the bug you refuse to acknowledge exists that everyone here has told you about thusfar.
If you dont like it, then call in, and pay 99 to have the client swapped for an h25
Sent from my PG06100 using Tapatalk 2
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
I certainly can't. I don't think anyone else can either. I don't know why you are asking, I've told you why you get failures....and so have other people.
twizt3dsist3r
2,962
212
Reread what i said and when im able to get no error, it was poorly worded sarcasam since no client would be in that example. And i confirm the bug as well.
Hutch1814
2,384
70
Indiana
Problem is the OP doesn't like the answer and wants a different one. He jumped on the Genie system after reading the issue and regrets it now from what I see, I could be wrong though. I agree with you kitty, pony up $99+$49 and get an HD receiver to replace the client.
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
Sorry, I read what you said. I was replying to the OP...
twizt3dsist3r
2,962
212
Im not 100% sure but i think the problem is with the client and not the genie itself with this particular bug. So yea.. swap the client to a hd if it bothers ya that much.
But what do we know.. were just installers lol.
Hutch1814
2,384
70
Indiana
harshness
18,898
4,066
Salem, OR
Yes, under extraordinary circumstances it is possible that the test will pass as anecdotal testimony proves.
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
If you don't have a client it will pass (obviously).
If you have a client and never switch it off and never download new software to the client it will pass.
Liquidforce88
3,738
39
The Land Of OZ
The system test is a tool for installers. Not meant to tell the customer anything. If you are having problems with your Directv system call and have a service call created.
