T tooold Active SatelliteGuys Member Original poster Mar 16, 2007 15 1 north carolina Apr 11, 2015 #1 when receiver is turned on it flashes MICROHD on a blue screen about every ten seconds. that is all it will do
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 26,919 7,274 EM75xb Apr 11, 2015 #2 You have ran into the infamous boot-loop issue with the microHD. Below it a link with a PDF that tells you have to fix with a TTL cable and where to buy a cable if you don't have one. http://www.satelliteguys.us/xen/thr...serial-update-via-internal-ttl-header.291053/
N6BY Geek Lifetime Supporter Mar 1, 2006 3,184 3,068 Roseville, CA 121W Apr 11, 2015 #3 Or you can make your own cable if you already have a USB to TTL serial adapter. Here is a link to make your own: http://www.satelliteguys.us/xen/threads/micro-hd-recovery-cable.345296/ Post #4 is where I illustrated how to wire it to the inside of the Micro HD. Reactions: KE4EST
