Multiswitch Question
tknopf
46
Wausau, Wisconsin
I have a 2 dish setup to receive D* sats. The 2 dishes go into a multiswitch. The sat lines then come in to my house from the Multiswitch. Right now I have an HR10-250 and then 3 SD Tivo/SAT Receivers. I want to swap out my SD Tivo/SAT Receiver in my bedroom with an HR10-250. Can I use the existing dual tuner satellite inputs that go into the SD Tivo/SAT Receiver with the HR10-250? I assume I just do a guided setup and then the HR10-250 should recognize the Sats. Is this correct, or am I missing something? Any clarification or help would be greatly appreciated.
I think you are asking if the 2 coax you are using for the SD Tivo (which you are swapping out) can be used on the HR10, if so, than yes, you can.
