No signal
mahogany
38
After not running TT or my sirius radio over the weekend, I went to set it up to record Stern. I am not getting a signal and my channel listing does not load. I checked the antenna on the roof and all is connected. I live in the Chicago area and was wondering if there is a problem with the Satallite that feeds our area. Any hints on how to get it working again?
I can assure you that there's nothing wrong with the satellite. If there was you'd see hundreds of posts about it on sites like XM411 and XMFan. Occam's razor falls into play here. The most simple answer is the most likely one. Check for kinks in the cable (present or past) that may have broken the wire inside. Check your actual connectors carefully.
I did exactly that, I even plugged the car antanne that came with it and still no signal (I am using Sirius and did a check and found no complaints about it being out) I disconnnect and re connected everything and still no signal,
I lost my signal overnight as well (Monday night). Says no antenna connected. But my subscription was supposed to run out this month on the radio I was using with the TT interface so I assumed that was the problem. I use Sirius Recorder software though.
