i am looking for opinions on the SG9120 55mm shaft and the DG380 55mm shaft motors to run my 1.2 m dish
I was reading about this problem on different sites.I never owned a DG380 or a STAB motor. The rest of them are junk to poor. The FTA market is still looking for a decent KU motor. Right now I have a SG9120 in use. It's still working albeit slower than molasses in winter. I've heard good things about STAB brand and the DG380. But I went prematurely grey trying to make KU motors work well. LOL The best motor I had was DMSI SG2100 that I modded for external power supply. I may get a 55mm shaft for it and use it again.
pacificrim said:I'm loving the Stab HH-120 I purchased as part of my Operation No More Junk where I rebuilt my setup using only quality parts. It is slower than my SG9120 was but has been rock solid in extreme winds and always accurate.
Where can you buy the stab HH-120 motor ? I looking to motorize a geosat pro 1.2m I purchased last year from satellite av
2. somewhat limited degree of travel. It only goes +/- 65 degrees (+/- 70max due to mechanical limits) so for you @ 97.5W it will only go to 97.5-65=32.5W so might not get Hispasat @ 30W?
Kevin
does the dg380 do usals? i was under the assumption the dg380 doesn't do usals. thanks, charlie
