RG6 cable for VOOM
agi
80
I currently have Perfect Vision RG6 cable with no info on the cable whatsoever.
I am replacing my high speed internet cable from the cheapest coax you have ever seen installed by Comcast to some Carol brand cable RG6/U (Home Depot) that will be burried.
Should I get the same Carol cable for Voom while I am replacing cables or should I keep that PV RG6 cable as it is?
Thanks!
I searched the forums for like 3 days and found nothing about what I am asking.
agi
80
Well they did, but isn't the Perfect Vision RG6 (no other info) a cheap cable. Do I need a cable that will be RG6/U (for burial) and that will be sweep tested to at least 2.2MHZ?
SatinstallerhatesVOOM
Jan 20, 2005
26
If you are burying the cable your best bet is to get whats called flooded cable. It has a silicon inside of it. Its a little better for direct burial. Most RG-6 cables today are good for all satellite installs. Yes it should be sweep tested for 2.2 MHZ though.
