Satellite AV Contest - GEOSATpro SL1PLL - Enter to Win - Drawing on 7/23/2012
SatelliteAV
6,486
186
Roseville, CA
Next Monday there will be Five Winners of the new GEOSATpro SL1PLL LNBF!
Will you be one of the lucky SatelliteGuy winners?
An incredible Lifetime Warranty* on an outstanding KU-band LNBF! Introducing the revolutionary GEOSATpro SL1PLL - The World's only Standard type LNBF with PLL circuitry. Now a home viewer has access to a quality professional grade LNBF! The SL1PLL is the perfect replacement LNBF for any Glorystar, FTA, hobbyist or commercial system.
GEOSATpro has partnered with a leading LNB manufacturer to design and produce another first for the satellite industry. The SL1PLL may be the last LNBF that you will ever need to purchase! Why do we make this claim? The SL1PLL offers a lifetime warranty, guaranteeing your SL1PLL LNBF to be free of any manufacturing or design defects, an unbelievable maximum +/- 300KHz frequency drift and absolutely no UV related damage for as long as you own your satellite system. What makes this LNBF so unique and special? PLL (Phase Locked Loop) LNBs are typically only found in high end commercial systems and historically cost 10, 20 or even 30 times or more than the LNBFs produced for the residential customers. The SL1PLL is a breakthrough LNBF, built with the highest grade materials and the latest RDA chipset and PCB technology. Recent technology allow for cost effective production of PLL LNBFs with lower current draws, lower heat generation, lower internal noise generation and increased performance.
The SL1PLL has been designed to meet the requirements for commercial applications and the most demanding satellite hobbyist. Reliable reception of digital HD MPEG4 channels with low symbol rates or high FEC requires an LNBF that excels in several performance benchmarks. The SL1PLL has exceptional flat gain across the 11.7 - 12.2GHz frequency range, features an excellent phase noise rating with low internal noise generation during signal conversion / amplification and stable frequency tuning for narrow bandwidth signals.
Regular LNBFs are designed to last only five to seven years. Slowly, a typical DRO LNBF loses performance as the mechanically tuned frequencies slowly drift until one day the receiver is no longer capable of tuning the satellite channels. PLL LNBFs do not rely on a mechanical tuning slug that may shift off frequency due to physical damage or aging. PLL LNBFs have an internal crystal oscillator that will remain tuned on frequency even in the harshest the environmental conditions.
Most LNBFs are not UV rated to protect against prolonged exposure to the sun. Often, the LNBF's white cap becomes brittle and cracks after just a few years and the feedhorn fills with water damaging or shorting out the electronics. The SL1 PLL LNBF feedhorn cap and the case will not fail as it has been tested and proven to resist the effects of 15 years of extreme 24/7 UV exposure! This is equal to over 30 years exposure mounted on a satellite dish!
If you are not completely satisfied with the performance of the GEOSATpro SL1PLL, we will promptly refund you for your SL1 PLL purchase! We are that confident!
GEOSATpro SL1PLL Product Specifications
Frequency Range11.7 - 12.2GHz
IF Range950 - 1450MHz
LO Frequency10750MHz
LO Drift+/-300KHz (max)
LO Phase Noise-70dBc/Hz@1KHz
-80dBc/Hz@10KHz
-100dBc/Hz@100KHz
LO Spurious Noise-50dBc
Noise Figure0.5dB@25°c
Conversion Gain60dB
Gain Variation2dB
Gain Flatness0.55dB/27MHz
Image Rejection42dB
Isolation22dB
P1dB1.5dBm
Output VSWR1.5:1
Polarization Switch V = 12 - 15vdc
H = 17 - 20vdc
DC Current Draw160mA (max)
Temperature Range-30°c - +60°c
FD Ratio.5 - .6
UV Rating15 years
Waterproof Test60°c@10 minutes (min)
* Lifetime Warranty provides replacement or repair at the discretion of Satellite AV, LLC for product failure as a result of factory defect or sun damage. Lifetime Warranty does not cover physical damage caused by improper product installation, usage, handling or failures related to acts of nature. Lifetime Warranty covers only the product replacement. The customer is responsible for shipping and handling charges.
How do I win?
Reply to this thread, inserting your username and pledge with this statement: "I, (insert SatelliteGuy user name here), promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
Small print:
This contest is open to any SatelliteGuys member who is in good standing with the exception of Satellite AV staff and members of their families. One entry per SatelliteGuy Member. Contest ends 8am, PT, 7/23/2012.
A drawing of 5 winners to each receive one GEOSATpro SL1PLL LNBF. The drawing will be made by a member of our staff on July 23rd, 2012. If a winner does not respond to our SatelliteGuys PM notification within 10 days, the prize will be forfeited and the unit will be offered to another contestant by random drawing.
This prize will be shipped free of charge via USPS to any continental US or Canadian residence or business address. If you are outside of the Continental US or Canada, you will be responsible for all shipping cost and any brokerage and/or customs fees.
Good Luck to All SatelliteGuys Members!
I, WhyMe, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
"I, Frijid, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
"I, (papabruski), promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
I, Cham, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
I have some good LNBFs to it compare to. :)
"I, Babadem, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
"I, gabshere, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
I,Turbosat, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
I, the mighty Iceberg, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
"I, hwm, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
But wait, there's more! Color photos sized for optimal web viewing will be included in my review.
I, tripinva, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
- Trip
"I, Tron, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
I, Zeb128, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize
I, b54so, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
I, vanalex, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize.
"I, Pixl, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
"I, Corrado, promise to honestly review the new SL1PLL LNBF to the best of my ability on the Satelliteguys forum within one week of receiving my prize."
Thanks for the contest and the chance to win, Brian.
