Hi aging
Ok order a fta system from satellite av. Never set up one of these units but did set up dish network when it first came out years ago. But this might be where I am in the wrong forum to ask this part of the question.
I also have a outdoor aerial so I order a Diplexer DPD2 Switch. I know that should work to bring both sat and over the air on one cable into the house. But now thinking some more my aerial has a rotor built into it. It gets the power over the rg6 one cable does both motor and video return.
Well I run into problems using a aerial like this on the same line as the dish even with switch?
Also before I hook this up I order a flat rg6 cable so I can run it into the door and not have to drill since I rent. Is the flat cable ok to use it is rg6 12 inch?
