D davemich SatelliteGuys Family Original poster Feb 8, 2006 83 0 SW Lower Michigan Nov 15, 2010 #1 Neither Home Depot or Lowes carry any. Does anybody know a good source to get these?
Timshow Member Oct 26, 2010 9 0 Pittsburgh Nov 15, 2010 #2 Try a water line I just had my pole mounted system installed on Saturday. I bought my 2" OD galvanized Water line at home depot. you could try this .
jdspencer SatelliteGuys Pro Oct 22, 2004 4,088 18 Binghamton, NY Nov 15, 2010 #3 Try a fence company. I had a leftover pipe (slightly < 2") and used that. I did have to shim it up a little using two wraps of aluminum flashing.
raoul5788 Studebaker driver Staff member HERE TO HELP YOU! Supporting Founder Lifetime Supporter Dec 28, 2004 32,786 17,726 Cheshire CT Nov 15, 2010 #4 jdspencer said: Try a fence company. I had a leftover pipe (slightly < 2") and used that. I did have to shim it up a little using two wraps of aluminum flashing. Click to expand... That's exactly what I did.
JustanOldfart SatelliteGuys Family Dec 22, 2005 48 8 Fredericksburg, TX Nov 15, 2010 #5 Did basically the same. I used 1.5" rigid conduit (1.9" OD) with a wrap of .035" flashing.
M mdram SatelliteGuys Pro Aug 24, 2005 4,078 807 Md Nov 15, 2010 #6 there is no standard 2" od pipe that i am aware of both sched 80 and sched 40 are actually 1.9" od the 2" is a nominal diameter its like a 2x4, its not actually 2x4 its @ 1.5x3.5
charper1 Bourbon Tester Supporting Founder May 18, 2004 18,442 6 I'm Nationwide Nov 15, 2010 #7 Ditto above.... and a plumbing / pipe company is always a best bet.
SA Holly Springs GA SatelliteGuys Pro Sep 10, 2010 391 0 In the woods Nov 15, 2010 #8 Fence company over Home Depot and Lowes. The one we use is $6/pole compared to Home Depots $20/pole. Thicker pole as well.
webbydude SatelliteGuys Master Feb 6, 2005 5,339 1 Akron, Ohio, United States Nov 15, 2010 #9 Local muffler shop down the road works for me. $12 for a 10' section.
