Had a Dish Installer add a 625. I have a Super Dish with a DP34 switch. Both the 721 and 522 are connected to the switch and everything runs fine.
Installer needed to add the 625 upstars, he kept insisting on me taking out the 721 and just running the 625 TV 2 into the kids room. I said no I want all 3 boxes hooked up.
He added a a second DP34. He added the 625 to the initial switch and moved the 721 to new one he installed. Every thing looked good the 625 was activted and the 522 came on as normal. I made the mistake of not looking at the switch, I thought the 721 was on the initial switch (but he moved it to the new one). The 721 usually takes a while recover from a hard reset ( about 9 minutes sometimes).
The installer left and I went to check on the 721 and I saw it was still downloading guide date. I did a check switch on the 721 and it shows my 3 sats
119----/105/110
Green/N.C./N.C
I said uh oh and went to check his switch setup, that's when I saw that he moved the 721 to the new switch.
So I swaped the 721 with the 625 and the 522 and here is what the dish screen showed
119----/105/110
Green/XXXX/XXXX
Reception Failed (or something like that)
I called Dish and the installers office (which seems closed). Dish has rescheduled an appointment for Tuesday. The CSR apologized the whole time.
The new DP34 switch that was installed just has the 2 lines(going to the 721) and 3 lines coming from the the first switch.
Yeah I made of mistake of not checking the switch setup before he left, i had my parents do a pop in visit and I wasn't thinking straight.
So if you guys can help, thanks.
119----/105/110
Green/N.C./N.C
119----/105/110
Green/XXXX/XXXX
