Tuner hangs on interactive channel
hobie16
104
USA (Full time RV'er
New problem just showed up on my 722K. When I scan through the channels, either up or down, I get stalled at the interactive channel. I can't go up, down or recall; the only way to proceed is to push "select", start the interactive download and then push recall. The receiver will return to the previous channel. My info screen says I am at L753 software. I have done a power down, pull plug, reboot but no change.
anyone else have this problem?:confused:
I believe it is set to work like this. If you don't use the interactive channel, you can lock it out which should skip over the channel. I'm not sure if using favorites will work (it should but it is easily switched to different list).
That's not the way it has been working. When you scan into an interactive channel (95,96,100) you get a message (326) to either enter by pushing select or changing channels up or down with the remote arrows. This no longer works.
mine does the same bs....seems I can pass it going down but not up....never did it before the last firmware update that I know of...
Auto Renew of Center Ice
uhf remote for dish 512 receiver
