Two simple questions
ericl
Jan 25, 2005
30
How do I determine my televisions (Sony KDF-50WE655) Native Resolution?
How do I determine the signal strength of my dish?
Thanks in advance
vurbano
On Double Secret Probation
23,815
104
Newport News, VA
Looks like your native resolution is 720p
Description: KDF-50WE655 50" LCD Projection TV (16:9, HDTV Compatible)
Manufacturer: Sony
Lowest Price: $2,092.96
User Rating: (4.36 / 5.00) - (Read 11 Reviews)
Broadcast Format Supported: 1080i (HDTV), 480i (SDTV), 480p (EDTV), 720p (HDTV)
Detailed Specifications
Product Type: LCD Rear Projection TV
General Features: 3/2 Pulldown, Channel Label, Closed Caption, Multi-Language Menu, On Screen Menu, V-Chip
Remote Control: Same Brand Remote
Aspect Ratio: 16:9 (Widescreen)
Audio Format Supported: SRS
Comb Filter: 3D Digital
Diagonal Screen Size: 50 in
HDTV Built-in Tuner: Yes
HDTV Compatible: Yes
Picture in Picture: Dual Tuner PIP
Progressive Scan: Yes
Resolution: 1386 x 788
Video Broadcast Standards: ATSC (Digital), NTSC (analog)
Input: A/V (Composite), Analog Coaxial(RF), Front A/V (Composite), Front S-Video, HD Component Video, HDMI, S-Video
Output: Digital Optical, Variable/Fixed Audio
Slots: cableCARD, Memory Stick
Dimensions
Height: 36.5 in
Width: 54.17 in
Depth: 17.28 in
Weight: 85 lbs
Reference
Warranty Information: 1 Year Limited Warranty
URL: Manufacturer Link
vurbano
23,815
104
Newport News, VA
rvsixer said:
Specs for the set indicate 1386x788 (which is not 720p).
Yes 720p is 1280x720p. His is a bit better. its progressive 788. But he needs to set his stb at 720p
vurbano
23,815
104
Newport News, VA
ericl said:
Which one is it guys?
1080i is 1920x1080i (interlaced)
720p is 1280x720p (progressive)
your set is 788 p
<TABLE borderColor=blue cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD vAlign=center colSpan=5>Key Features:
</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>High-Definition TV — receives and decodes digital HDTV/SDTV signals from over-the-air broadcasts (antenna required) and cable TV service (CableCARD required)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>widescreen 16:9 aspect ratio</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>1386 x 788 pixels (all signals displayed at 788p)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>130°(H) x 60°(V) viewing angle</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>high-contrast protective screen with anti-reflective coating</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>Wega Engine video processing</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>adjustable DRC MultiFunction V1 (upconverts non-HD signals)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>CineMotion™ 3-2 pulldown processing</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>selectable color temperature control</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>Twin View™ 2-tuner PIP (split-screen)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>built-in stereo speakers</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>30-watt S-Master® 1-bit digital amplifier
(5 x 2, plus 20 watts for woofer)
</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>multibrand remote control</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>picture settings memory for each video input</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>7 A/V inputs, including:</TD></TR><TR><TD></TD><TD></TD><TD vAlign=top align=right></TD><TD vAlign=top colSpan=2>4 composite video (3 rear, 1 front)</TD></TR><TR><TD></TD><TD></TD><TD vAlign=top align=right></TD><TD vAlign=top colSpan=2>4 S-video (3 rear, 1 front)</TD></TR><TR><TD></TD><TD></TD><TD vAlign=top align=right></TD><TD vAlign=top colSpan=2>2 rear-panel HD-compatible component video
(accepts 1080i/720p/480p/480i signals)
</TD></TR><TR><TD></TD><TD></TD><TD vAlign=top align=right></TD><TD vAlign=top colSpan=2>1 rear-panel HDMI digital audio/video input with HDCP copy protection</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>2 RF inputs (1 Antenna, 1 Cable)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>Memory Stick slot (JPEG, MPEG1)</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>optical digital audio output for Dolby® Digital</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>Energy Star® compliant</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>54-3/16"W x 36-11/16"H x 17-3/4"D</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>weight: 85.9 lbs.</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>warranty: 1 year parts & labor</TD></TR><TR><TD></TD><TD vAlign=top>» </TD><TD vAlign=top colSpan=3>Contact your local cable provider for details regarding the availability and costs of CableCARD-related services</TD></TR></TBODY></TABLE>
use 720p on the stb
ericl
Jan 25, 2005
30
So I set the voom box on 720? Thanks, will this also help with the standard stations? Also the tv has a noise filter setting will this help with the slightly fuzzy standard stations?
Thanks for all of your help
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
31,337
19,244
NE OH
Yes, Sony has a non-standard resolution of 788p.
I feed VOOM's unchanged 1080i and let the TV set do the conversion.
Switch to a satellite channel (e.g. 100) and then press HELP-INFO-OK
Then press DOWN 2-3 times until you see the signal readings.
ericl
Jan 25, 2005
30
Thanks Ilya, That is what I have the Televison set on now, I know that if I can educate myself I can get the maximum enjoyment
rvsixer
203
Again, per the specs the set accepts 480i/480p/720p/1080i, so for HD I would try both 720p and 1080i and leave it at whatever looks best (i.e. find out if the stb or the Sony has the better scaler).
Rob.
Ilya
Staff member
HERE TO HELP YOU!
31,337
19,244
NE OH
ericl said:
Understand, how to set the box, not sure how to set the TV
Just set the box. The TV set will know what to do! ;)
ericl
Jan 25, 2005
30
thanks guys, know anything about the noise filter on the Sony?
Ilya
Staff member
HERE TO HELP YOU!
31,337
19,244
NE OH
Doesn't it work for SD signal only?
I don't know. I try not to filter anything. I like it the way it is... ;)
