Using direct slimline with orby?
I measured where the original lnbf was and used a standard FTA lnbf with a universal mount. Dish is at zero skew, lnbf is skewed. It is mounted on top of the pole for my motorized ku dish. I rushed putting this up during really cold weather, :snow which bothers my hands horribly, so it likely can be dialed in a little better but so far it has worked great. :D
Images below are thumbnailed - click for larger view.
View attachment 144401 View attachment 144402
Thanks for the pictures and the info i would like to try it this way now which would mean i could use a dish that doesnt have a skew setting and i have several of those lying around.
Reactions: FTA4PA
As others have mentioned the Direct TV world direct dish and LNBF do work, currently using it in my setup.
Was a DTV tech, so had extras in my garage.
Only problem I think the dish tilt is not enough to get optimum signal in my lication.
Slimline works just fine with linear lnb
what is orby satellite?
I Found The OTA Signal Meter!
