GEOSATpro Using the "Signal" screen ?
tekjunkie02
175
6
n.fla
What are the requirements to invoke the "Signal" screen? Basically, I'd like to know if I can enter the parameters of a satellite and transponder, then bring up the signal screen to use for tuning dish and lnb? Thanks,
Before scanning a channel, a signal meter is only available in the installation screens.
Once the channel is scanned or if it has been loaded via the .udf file, you may press the Signal key to display the full screen meter with 6 second histograph. A smaller Signal Meter with complete channel data is available when the INFO key is pressed twice.
Brian,
In this review ke4est made a chart using the microHD and in one column he list the numerical value of the CNR. I have the latest firmware installed on my microHD and I can not see the CNR on any of the screens (Signal Level, Info, etc.). Where do I find the CNR?
Most likely right Ice, he shows the signal level in dB?V so one would assume the CNR came from that same device (dedicated satellite meter).
Yes I was also using a signal meter. ;)
Sent from my DROID 2 using SatelliteGuys
GEOSATpro Full Screen Signal Meter
GEOSATpro MicroHd
