[VOOM] voom box questions
G
gin_chen
Guest
Could experts in this group answer a couple of questions for me:
1. Does DVI and component ports on the back of Voom box output at
the same time? Is it possible to connect 2 TVs using component & DVI
at the same time?
2. If I need to connect Voom DVI port to my Benq projector which has
VGA port, do I need a DVI-D to VGA adapter? I can't seem to find
such kind of adapter.
Thanks in advance...
------------------------ Yahoo! Groups Sponsor --------------------~-->
Yahoo! Domains - Claim yours for only $14.70
http://us.click.yahoo.com/Z1wmxD/DREIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Yes, all (6) video and (4) audio outputs are active at the same time. So, yes you can connect several TVs to one STB, but they will all show the same channel!
VOOM doesn't offer RGB output (only Y/Pr/Pb). You might be able to find an Y/Pr/Pb to RGB converter, but those are rather expensive.
In case you have further questions about the box, I put together a FAQ about VOOM Set-Top Box. You can find it here: http://www.satelliteguys.us/showthread.php?t=13946
at the same time?
[VOOM] Re: voom box questions
Thank you very much, Ilya.
> the same channel!
> about VOOM Set-Top Box. You can find it here: http://tinyurl.com/4bs5g
> > at the same time?
> Ilya
Yahoo! Groups Links
Similar threads
