Created by JohnH, DBSTalk
02-13-2008,13:21:23
359 CSNWS MPEG4 HD REMOVED FROM Tp 27 ConUS beam on EchoStar 5 at 129w
360 ALTUD MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
361 PRIME MPEG4 HD REMOVED FROM Tp 27 ConUS beam on EchoStar 5 at 129w
362 MSG MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
363 FOXNY MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
364 FOXRM MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
365 FOXAZ MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
366 FOXSW MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
367 FOXW MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
368 FOXMW MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
369 FOXBA MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
370 FOXS MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
372 SUN MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
373 FOXFL MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
374 CSNMA MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
374 CSNMA MPEG4 HD REMOVED FROM Tp 27 ConUS beam on EchoStar 5 at 129w
375 FOXOH MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
376 FOXNW MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
377 FOXCN MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
378 FOXPT MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
378 FOXPT MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
379 CSNCH MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
380 FOXD MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
381 STO MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
385 CSNNE MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
386 FOXN MPEG4 HD REMOVED FROM Tp 8 ConUS beam on EchoStar 5 at 129w
387 SPSOU MPEG4 HD REMOVED FROM Tp 27 ConUS beam on EchoStar 5 at 129w
388 SNY MPEG4 HD REMOVED FROM Tp 30 on EchoStar 3 at 61.5w
513 PPV MOVED FROM Tp 16 on EchoStar 8 at 110w MPEG2 SD
TO Tp 13 on Rainbow 1 at 61.5w MPEG4 SD
513 PPV ADDED TO Tp 16 on EchoStar 8 at 110w MPEG2 SD
514 PPV MOVED FROM Tp 6 on EchoStar 8 at 110w MPEG2 SD
514 PPV ADDED TO Tp 6 on EchoStar 8 at 110w MPEG2 SD
517 PPV MOVED FROM Tp 2 on EchoStar 8 at 110w MPEG2 SD
517 PPV ADDED TO Tp 2 on EchoStar 8 at 110w MPEG2 SD
520 PPV MOVED FROM Tp 14 on EchoStar 8 at 110w MPEG2 SD
520 PPV ADDED TO Tp 14 on EchoStar 8 at 110w MPEG2 SD
523 PPV MOVED FROM Tp 8 on EchoStar 8 at 110w MPEG2 SD
523 PPV ADDED TO Tp 8 on EchoStar 8 at 110w MPEG2 SD
574 FPCHN MOVED FROM Tp 29 on EchoStar 3 at 61.5w MPEG2 SD
TO Tp 8 on EchoStar 3 at 61.5w MPEG2 SD
574 FPCHN MOVED FROM Tp 19 on EchoStar 1 at 148w MPEG2 SD
TO Tp 9 on EchoStar 1 at 148w MPEG2 SD
575 FPCHN MOVED FROM Tp 8 on EchoStar 3 at 61.5w MPEG2 SD
TO Tp 12 on EchoStar 3 at 61.5w MPEG2 SD
655 WOWTV MPEG2 SD REMOVED FROM Tp 14 on EchoStar 3 at 61.5w
655 WOWTV MPEG2 SD REMOVED FROM Tp 7 on EchoStar 1 at 148w
691 CTS MOVED FROM Tp 10 on EchoStar 9 at 121w MPEG2 SD
TO Tp 13 on EchoStar 9 at 121w MPEG2 SD
694 CCTV9 MOVED FROM Tp 10 on EchoStar 9 at 121w MPEG2 SD
695 CCTVE MOVED FROM Tp 10 on EchoStar 9 at 121w MPEG2 SD
699 CCOPR MOVED FROM Tp 17 on EchoStar 9 at 121w MPEG2 SD
716 VIDIT MPEG2 SD REMOVED FROM Tp 14 on EchoStar 3 at 61.5w
716 VIDIT MPEG2 SD REMOVED FROM Tp 7 on EchoStar 1 at 148w
758 ART MOVED FROM Tp 29 on EchoStar 9 at 121w MPEG2 SD
764 FUTUR MOVED FROM Tp 22 on EchoStar 9 at 121w MPEG2 SD
766 MBC MOVED FROM Tp 21 on EchoStar 9 at 121w MPEG2 SD
772 ALARA MOVED FROM Tp 26 on EchoStar 9 at 121w MPEG2 SD
773 IQRAA MOVED FROM Tp 26 on EchoStar 9 at 121w MPEG2 SD
5409 CSNWS ADDED TO Tp 27 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5410 ALTUD ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5411 PRIME ADDED TO Tp 27 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5412 MSG ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5413 FOXNY ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5414 FOXRM ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5415 MT65 MOVED FROM Tp 11 ConUS beam on EchoStar 5 at 129w MPEG4 HD
TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD RENAMED FOXAZ
5416 MT66 MOVED FROM Tp 11 ConUS beam on EchoStar 5 at 129w MPEG4 HD
TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD RENAMED FOXSW
5417 FOXW ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5418 MT68 MOVED FROM Tp 31 ConUS beam on EchoStar 5 at 129w MPEG2 HD
TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD RENAMED FOXMW
5419 FOXBA ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5420 FOXS ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5422 SUN ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5423 FOXFL ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5424 CSNMA ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5424 CSNMA ADDED TO Tp 27 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5425 FOXOH ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5426 FOXNW ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5427 FOXCN ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5428 FOXPT ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5428 FOXPT ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5429 CSNCH ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5430 FOXD ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5431 STO ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5435 CSNNE ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5436 FOXN ADDED TO Tp 8 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5437 SPSOU ADDED TO Tp 27 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5438 SNY ADDED TO Tp 30 on EchoStar 3 at 61.5w MPEG4 HD
5455 MT65 ADDED TO Tp 11 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5456 MT66 ADDED TO Tp 11 ConUS beam on EchoStar 5 at 129w MPEG4 HD
5458 MT68 ADDED TO Tp 31 ConUS beam on EchoStar 5 at 129w MPEG2 HD
5708 CTS ADDED TO Tp 10 on EchoStar 9 at 121w MPEG2 SD
5709 ART ADDED TO Tp 29 on EchoStar 9 at 121w MPEG2 SD
5718 FUTUR ADDED TO Tp 22 on EchoStar 9 at 121w MPEG2 SD
5721 MBC ADDED TO Tp 21 on EchoStar 9 at 121w MPEG2 SD
5722 VIDIT MPEG2 SD REMOVED FROM Tp 27 on EchoStar 3 at 61.5w
5722 VIDIT MPEG2 SD REMOVED FROM Tp 1 on EchoStar 1 at 148w
5724 WOWTV MPEG2 SD REMOVED FROM Tp 10 on EchoStar 3 at 61.5w
5724 WOWTV MPEG2 SD REMOVED FROM Tp 3 on EchoStar 1 at 148w
5725 ALARA ADDED TO Tp 26 on EchoStar 9 at 121w MPEG2 SD
5726 IQRAA ADDED TO Tp 26 on EchoStar 9 at 121w MPEG2 SD
5727 RTPI MPEG2 SD REMOVED FROM Tp 6 on EchoStar 9 at 121w
5976 XWVAW ADDED TO Tp 7 on AMC 15 at 105w MPEG2 SD
5977 XWCAV ADDED TO Tp 7 on AMC 15 at 105w MPEG2 SD
7041 WJET MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
TO Tp 30 on EchoStar 9 at 121w MPEG2 SD
7042 WSEE MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
7210 WAOW MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
TO Tp 1 on EchoStar 9 at 121w MPEG2 SD
7211 WSAW MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
7778 WAPAD ADDED TO Tp 25 Spotbeam 49 from Cheyenne for EchoStar 10 at 110w MPEG2 SD
7860 KSWO MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
TO Tp 9 on EchoStar 9 at 121w MPEG2 SD
7861 KAUZ MOVED FROM Tp 14 on EchoStar 9 at 121w MPEG2 SD
7929 WVAW MOVED FROM Tp 7 on AMC 15 at 105w MPEG2 SD
TO Tp 2 on AMC 15 at 105w MPEG2 SD
7930 WCAV MOVED FROM Tp 7 on AMC 15 at 105w MPEG2 SD
8279 WTMO ADDED TO Tp 29 Spotbeam 1 from Mount Jackson for EchoStar 10 at 110w MPEG2 SD
9190 KCAH TP 23 Spotbeam 42 from Spokane for EchoStar 10 at 110w MPEG2 SD RENAMED KQET
9955 TST16 ADDED TO Tp 23 on EchoStar 1 at 148w MPEG2 SD
14233 KNVA2 EEPG REMOVED FROM Tp 7s10 on EchoStar 7 at 119w
14507 KXAN2 EEPG REMOVED FROM Tp 7s10 on EchoStar 7 at 119w
14508 KXAN3 EEPG REMOVED FROM Tp 7s10 on EchoStar 7 at 119w
14510 WPMT2 EEPG REMOVED FROM Tp 18 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
15049 KOCE3 EEPG REMOVED FROM Tp 1s5 on EchoStar 7 at 119w
15097 WUPV2 EEPG REMOVED FROM Tp 31 Spotbeam 5 from Mount Jackson for EchoStar 10 at 110w
15118 KCAH2 TP 23 Spotbeam 42 from Spokane for EchoStar 10 at 110w EEPG RENAMED KQET2
15119 KCAH3 TP 23 Spotbeam 42 from Spokane for EchoStar 10 at 110w EEPG RENAMED KQET3
15120 KCAH4 TP 23 Spotbeam 42 from Spokane for EchoStar 10 at 110w EEPG RENAMED KQET4
15121 KCAH5 TP 23 Spotbeam 42 from Spokane for EchoStar 10 at 110w EEPG RENAMED KQET5
CHANGE COUNT 120
			02-13-2008,13:21:23
CHANGE COUNT 120
