DishNetwork Uplink Activity Report - 2/20/2008 12:40pm - 62 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/23/2008 - 62 changes
Uplink Comparison Range: 02/20/2008 12:16P - 02/20/2008 12:40P -
6810 - UP4 [MPEG4 HD] added to EchoStar4 77W TP 02 South ConUS beam (Not Available)
6811 - UP4 [MPEG4 HD] added to EchoStar4 77W TP 03 South ConUS beam (Not Available)
6812 - UP4 [MPEG4 HD] added to EchoStar4 77W TP 04 South ConUS beam (Not Available)
6813 - UP4 [MPEG4 HD] added to EchoStar4 77W TP 05 South ConUS beam (Not Available)
6814 - UP4 [MPEG4 HD] added to EchoStar4 77W TP 06 South ConUS beam (Not Available)
6815 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 07 South ConUS beam (Not Available)
6816 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 08 South ConUS beam (Not Available)
6817 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 09 South ConUS beam (Not Available)
6818 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 10 South ConUS beam (Not Available)
6819 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 11 South ConUS beam (Not Available)
6820 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 12 South ConUS beam (Not Available)
6821 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 13 South ConUS beam (Not Available)
6822 - UP5 [MPEG4 HD] added to EchoStar4 77W TP 14 South ConUS beam (Not Available)
6823 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 15 South ConUS beam (Not Available)
6824 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 16 South ConUS beam (Not Available)
6825 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 17 South ConUS beam (Not Available)
6826 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 18 South ConUS beam (Not Available)
6827 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 19 South ConUS beam (Not Available)
6828 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 20 South ConUS beam (Not Available)
6829 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 21 South ConUS beam (Not Available)
6830 - UP6 [MPEG4 HD] added to EchoStar4 77W TP 22 South ConUS beam (Not Available)
6831 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 23 South ConUS beam (Not Available)
6832 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 24 South ConUS beam (Not Available)
6833 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 25 South ConUS beam (Not Available)
6834 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 26 South ConUS beam (Not Available)
6835 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 27 South ConUS beam (Not Available)
6836 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 28 South ConUS beam (Not Available)
6837 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 29 South ConUS beam (Not Available)
6838 - UP7 [MPEG4 HD] added to EchoStar4 77W TP 30 South ConUS beam (Not Available)
6839 - UP8 [MPEG4 HD] added to EchoStar4 77W TP 31 South ConUS beam (Not Available)
6840 - UP8 [MPEG4 HD] added to EchoStar4 77W TP 32 South ConUS beam (Not Available)
Transponder Changes:
EchoStar4 77W TP 02 South ConUS beam QPSK added to tables
EchoStar4 77W TP 03 South ConUS beam QPSK added to tables
EchoStar4 77W TP 04 South ConUS beam QPSK added to tables
EchoStar4 77W TP 05 South ConUS beam QPSK added to tables
EchoStar4 77W TP 06 South ConUS beam QPSK added to tables
EchoStar4 77W TP 07 South ConUS beam QPSK added to tables
EchoStar4 77W TP 08 South ConUS beam QPSK added to tables
EchoStar4 77W TP 09 South ConUS beam QPSK added to tables
EchoStar4 77W TP 10 South ConUS beam QPSK added to tables
EchoStar4 77W TP 11 South ConUS beam QPSK added to tables
EchoStar4 77W TP 12 South ConUS beam QPSK added to tables
EchoStar4 77W TP 13 South ConUS beam QPSK added to tables
EchoStar4 77W TP 14 South ConUS beam QPSK added to tables
EchoStar4 77W TP 15 South ConUS beam QPSK added to tables
EchoStar4 77W TP 16 South ConUS beam QPSK added to tables
EchoStar4 77W TP 17 South ConUS beam QPSK added to tables
EchoStar4 77W TP 18 South ConUS beam QPSK added to tables
EchoStar4 77W TP 19 South ConUS beam QPSK added to tables
EchoStar4 77W TP 20 South ConUS beam QPSK added to tables
EchoStar4 77W TP 21 South ConUS beam QPSK added to tables
EchoStar4 77W TP 22 South ConUS beam QPSK added to tables
EchoStar4 77W TP 23 South ConUS beam QPSK added to tables
EchoStar4 77W TP 24 South ConUS beam QPSK added to tables
EchoStar4 77W TP 25 South ConUS beam QPSK added to tables
EchoStar4 77W TP 26 South ConUS beam QPSK added to tables
EchoStar4 77W TP 27 South ConUS beam QPSK added to tables
EchoStar4 77W TP 28 South ConUS beam QPSK added to tables
EchoStar4 77W TP 29 South ConUS beam QPSK added to tables
EchoStar4 77W TP 30 South ConUS beam QPSK added to tables
EchoStar4 77W TP 31 South ConUS beam QPSK added to tables
EchoStar4 77W TP 32 South ConUS beam QPSK added to tables
Channels in the system: 4686
(A) = Available to subscribers
(NA) = Not Available
What the??? I thought Echo4 only had 6 working transponders.
And what is this mpeg4/QPSK stuff?
I just motored my 90cm over to 77w and scanned for life. Still only 4 TP's are physically active that I can see with my size dish.
digiblur can see 77 west, but there is likely not many signals there as there is not much in the way of signals from EchoStar 12 spotbeams, yet. This is more likely preliminary activity very similar to the activity which preceded the launch of EchoStar 10.
digiblur can see 77 west, but there is likley no signal there as there is not much in the way of signals from EchoStar 12 signals, yet. This is more likely preliminary activity very similar to the activity which preceded the launch of EchoStar 10.
I can see that this is just preliminary, but it does look like they intend to see just how healthy 77 West is now, by checking every transponder. The plan may be to use E4 if it's healthy enough, or move something else there when the new satellites go up.
Channel Number, Channel Name, Type, Satellite, Satellite Location, Transponder, and beam area.
I believe that is what it is!
More liklely a test to see if any receivers hiccup with all this extra info. :)
could the reports be opened as a locked thread and a discussion forum be opened daily so that the changes are discussed on a daily basis instead of on a "change" basis? I can just see a lot of comments might get lost if they're posted in a change forum
I hope this new format is MUCH easier for the Uplink people as it is MUCH harder for the reader.
PS I think that this "pub" blackmail is giong to start to create a backlash...
How so? I would think the comment would be more productive too if it were outside of an uplink thread for those of us who would like to discuss the latest changes.
Also, I dont see how what happened was blackmailing. These guys pay out of pocket for a lot of expenses. Not too much to ask for support and reward those who do.
D
DishNetwork Uplink Activity Report - 2/23/2008 2:30pm - 2 changes
D
DishNetwork Uplink Activity Report - 2/27/2008 12:55pm - 1 change
