Having trouble with 129
bigcountry25
5
I am having trouble getting a good siginal with the 129 bird and keeping the 110 bird good also, 119 is fine. I live in southeast missouri zip 63863 what should the elevation and skew be? Also could I just use 1 dish 500 pointed at 110&119 and the other pointed at 129 with a dp34 switch? Also what would be a good signal strength be for my area? Thanks
Dish says 63800 - 63899 216 40 119
Your problem is probably in elevation (up or down, but most likely up, just shy of 2 degrees.)
Which dish 1000 do you have? 1000 or 1000.2? You can use a separate dish but hooking it up depends on what dish you're using. Look here:
Identifying Dishes
