What Rating is Playboy Channel Programming?
Playboy TV has really gone downhill... It's the same repetitive content, chopped up into different blocks......
I hope they see subscribers plummet and then abandon this experiment quickly....
I also agree with you. I liked, when they actually had new episodes and did not repeat the same ole' same ole'. I just cancelled Shorteez because of repeating the same clips over and over. Coming from someone in the porn business, I like to see diverse items.
Late at night, it goes to X and XX. I don't know why.
This used to have something to do with cable's inability to deny programming to those who weren't supposed to be able to get it. If there's a chance that something goes out more or less "in the clear", decency rules apply. Until all of the security holes are closed, they'll have to do the late night thing as it is one of the few adult channels offered almost everywhere on a monthly basis.
I don't fancy that the Playboy channel will go much further into the "leave nothing to the imagination" territory lest they risk their ability to cast in pron-regulated areas.
Actually, they ARE cheaper than they used to be when you combine it with HBO or the Everything Pak I believe.....
While The Playboy Channel isn't part of the Everything Pak, it is considered a standard movie plex and is entitled to the same discounts.
It interesting to note that for three and four channels, the additional cost is $9 but the fifth channel is $10.
playboy pricing
IF you have the AEP package it is only an additional 7.00 dollars per month to add playboy.
If you have the DVR adv package with 2 or premiums it is 10.00 per month.
Alone it is 14.99/ month
hopefully that clears it up.
Thanks, I remembered my price going down by half on that channel about a year ago....
Will a long hdmi cable with equalizer work on 722?
FCC: Echostar Nearly Has National Reach For Wireless Broadband
