Uplink Activity Report - 7/29/2008 2:02am - 41 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/29/2008 1:41pm - 42 changes
Uplink Comparison Range: 07/29/2008 12:02A - 07/29/2008 01:01P
Channel Additions:
100 - HOME [173] added to Echostar6 72.7W TP 21 ConUS beam (A)
166 - CMT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
239 - WGN [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)(Chicago, IL)
322 - SHOEX [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
341 - ENCRW [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
345 - EDRAM [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
346 - ELOVE [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
456 - SPORT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
457 - SPORT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
494 - REAL [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
495 - PENT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
496 - XTSY [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
19007 - VOD [174] added to Echostar6 72.7W TP 21 ConUS beam (A)
19206 - OLYMP [DATA] added to EchoStar7 119W TP 13 ConUS beam (A) (H)
36862 - EEPG [EPG] added to Echostar6 72.7W TP 21 ConUS beam (A)
Channel Removals:
533 - PPV (A) removed from EchoStar1 148W TP 09 ConUS beam
533 - PPV (A) removed from Echostar12 61.5W TP 23 ConUS beam
573 - FPCHN (A) (H) removed from EchoStar1 148W TP 29 ConUS beam
573 - FPCHN (A) (H) removed from EchoStar3 61.5W TP 31 ConUS beam
580 - INFO (A) removed from EchoStar1 148W TP 09 ConUS beam
580 - INFO (A) removed from Echostar12 61.5W TP 23 ConUS beam
5992 - TEMP2 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
Channel Moves:
105 - USA [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
127 - OXYGN [MPEG2 SD] moved from EchoStar7 119W TP 17 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
327 - TMC-E [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 02 ConUS beam (A)
328 - TMCXE [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A)
410 - ALTUD [MPEG2 SD] moved from EchoStar7 119W TP 13 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A) (H)
472 - SPORT [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
578 - BRDGS [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
622 - APUNJ [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
623 - ZGUJ [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
702 - GLBL1 [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
703 - ISMOV [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
778 - NBN [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
902 - GEONW [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
998 - SMART [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
5961 - SMART [DATA] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9405 - PNTGN [MPEG2 SD] moved from EchoStar3 61.5W TP 27 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9418 - PAEC [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9621 - BTV [SD TV] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
9902 - D61.5 [FTA] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9996 - ECC [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
Channels in the system: 5053
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
UPLINK ACTIVITY: SAMPLE TAKEN 07-29-2008 03:02:00 TO 07-29-2008 03:03:04 ET
15 ADD(S)
ADD 100 HOME UNKNOWN Tp 21 EchoStar 72.7w
ADD 166 CMT MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 239 WGN{CHICAGO, IL} MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 322 SHOEX MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 341 ENCRW MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 345 EDRAM MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 346 ELOVE MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 456 SPORT MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 457 SPORT MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 494 REAL MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 495 PENT MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 496 XTSY MPEG4 SD Tp 21 EchoStar 72.7w UNAVAIL HIDE
ADD 19007 VOD UNKNOWN Tp 21 EchoStar 72.7w
ADD 19206 OLYMP DATA Tp 13 EchoStar 7 119w HIDE
ADD 36862 EEPG UNKNOWN Tp 21 EchoStar 72.7w AT100?
7 DELETE(S)
DEL 533 PPV MPEG2 SD Tp 23 Rainbow 1 61.5w AT200?
DEL 533 PPV MPEG2 SD Tp 9 EchoStar 1 148w AT200?
DEL 573 FPCHN MPEG2 SD Tp 31 EchoStar 3 61.5w AVAIL HIDE
DEL 573 FPCHN MPEG2 SD Tp 29 EchoStar 1 148w AVAIL HIDE
DEL 580 INFO MPEG2 SD Tp 23 Rainbow 1 61.5w AT100? PREV FTA
DEL 580 INFO MPEG2 SD Tp 9 EchoStar 1 148w AT100? PREV FTA
DEL 5992 TEMP2 SD TV Tp 23 Rainbow 1 61.5w UNAVAIL HIDE
20 MOVE(S) (May include other changes as well.)
MOVE 105 USA MPEG2 SD Tp 2 EchoStar 7 119w AT100?
TO 105 USA MPEG2 SD Tp 13 EchoStar 7 119w AT100?
MOVE 127 OXYGN MPEG2 SD Tp 17 EchoStar 7 119w AT200? PREV
TO 127 OXYGN MPEG2 SD Tp 13 EchoStar 7 119w AT200? PREV
MOVE 327 TMC-E MPEG2 SD Tp 10 EchoStar 7 119w AVAIL
TO 327 TMC-E MPEG2 SD Tp 2 EchoStar 7 119w AVAIL
MOVE 328 TMCXE MPEG2 SD Tp 10 EchoStar 7 119w AVAIL
TO 328 TMCXE MPEG2 SD Tp 17 EchoStar 7 119w AVAIL
MOVE 406 SETA MPEG2 SD Tp 18 EchoStar 3 61.5w SPORT?
TO 406 SETA MPEG2 SD Tp 19 Rainbow 1 61.5w SPORT?
MOVE 410 ALTUD MPEG2 SD Tp 13 EchoStar 7 119w SPORT? HIDE
TO 410 ALTUD MPEG2 SD Tp 10 EchoStar 7 119w SPORT? HIDE
MOVE 455 SPORT MPEG2 SD Tp 13 EchoStar 7 119w AT100?
TO 455 SPORT MPEG2 SD Tp 10 EchoStar 7 119w AT100?
MOVE 472 SPORT MPEG2 SD Tp 23 Rainbow 1 61.5w AT100?
TO 472 SPORT MPEG2 SD Tp 31 EchoStar 3 61.5w AT100?
MOVE 622 APUNJ MPEG2 SD Tp 23 Rainbow 1 61.5w AVAIL
TO 622 APUNJ MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL
MOVE 623 ZGUJ MPEG2 SD Tp 23 Rainbow 1 61.5w AVAIL HIDE
TO 623 ZGUJ MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL HIDE
MOVE 702 GLBL1 MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL HIDE
TO 702 GLBL1 MPEG2 SD Tp 8 EchoStar 3 61.5w AVAIL HIDE
MOVE 703 ISMOV MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL HIDE
TO 703 ISMOV MPEG2 SD Tp 14 EchoStar 3 61.5w AVAIL HIDE
MOVE 778 NBN MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL
TO 778 NBN MPEG2 SD Tp 14 EchoStar 3 61.5w AVAIL
MOVE 902 GEONW MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL HIDE
TO 902 GEONW MPEG2 SD Tp 27 EchoStar 3 61.5w AVAIL HIDE
MOVE 998 SMART MPEG2 SD Tp 8 EchoStar 3 61.5w AVAIL HIDE
TO 998 SMART MPEG2 SD Tp 10 EchoStar 3 61.5w AVAIL HIDE
MOVE 9405 PNTGN MPEG2 SD Tp 27 EchoStar 3 61.5w AT100? HIDE
TO 9405 PNTGN MPEG2 SD Tp 10 EchoStar 3 61.5w AT100? HIDE
MOVE 9418 PAEC MPEG2 SD Tp 23 Rainbow 1 61.5w AT100? HIDE
TO 9418 PAEC MPEG2 SD Tp 10 EchoStar 3 61.5w AT100? HIDE
MOVE 9621 BTV SD TV Tp 23 Rainbow 1 61.5w ADULT?
TO 9621 BTV SD TV Tp 18 EchoStar 3 61.5w ADULT?
MOVE 9902 D61.5 UNKNOWN Tp 14 EchoStar 3 61.5w AT100? PREV FTA
TO 9902 D61.5 UNKNOWN Tp 10 EchoStar 3 61.5w AT100? PREV FTA
MOVE 9996 ECC MPEG2 SD Tp 23 Rainbow 1 61.5w ADULT? HIDE
TO 9996 ECC MPEG2 SD Tp 10 EchoStar 3 61.5w ADULT? HIDE
42 CHANGE(S) 5053 CHANNELS IN THE SYSTEM
100 - HOME [173] added to Virtual77w 77W TP 21 ConUS beam (A)
166 - CMT [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
239 - WGN [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)(Chicago, IL)
322 - SHOEX [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
341 - ENCRW [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
345 - EDRAM [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
346 - ELOVE [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
456 - SPORT [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
457 - SPORT [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
494 - REAL [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
495 - PENT [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
496 - XTSY [MPEG4 SD] added to Virtual77w 77W TP 21 ConUS beam (NA)
19007 - VOD [174] added to Virtual77w 77W TP 21 ConUS beam (A)
36862 - EEPG [EPG] added to Virtual77w 77W TP 21 ConUS beam (A)
So the real start of eastern arc with some 77 action? (or is virtual 77 just getting the system ready for it?)
If you will check the second post, you will find it is not 77 but 72.7.
this is probably a dumb question but when the report says virtual 77w does this mean that there actually isn't a signal there yet? if not what does it mean?
It's just what I named it at the time since no satellite was there. I guess I can rename them to Echostar 6 when I fix the TID table.
i was kind of hoping they would change greenville, NC locals to (a) today, since they are "suppose" to be on by July 30th. . I guess I was wrong. Well there is always tomorrow. the real day!
Not much left (1 channel still available) on E12 TP23, and nothing on E12 T17. Possibly going to spots?
D
Uplink Activity Report - 8/1/2008 1:02am - 15 changes
D
Uplink Activity Report - 8/1/2008 2:02pm - 3 changes
