HR2x / R22 CE Release for 10/3
This is only my second CE download so I new to the program. I have two HR20-100's and after the download one of the HR20 lost all of the items in the prioritizer list where as the other HR20 did not.
Well leave me out of this one boys and girls. i am sufficiently frightened now after reading Jason's posts.
I went to bed and it appears it finally downloaded the advanced guide sometime overnight.
There's an issue with locals that the OTA module (AM21) receive - their mapping gets mixed up at times. When I go to the guide, it lists KTVD-DT which is on 20-1 onto 41-1 and then it goes back to normal when you check the guide later. Other channels (OTA) get mixed up like that as well but then they go back to where they are supposed to be when you check the guide again later. Pretty weird...
I plan on putting the receiver through its paces once the wife gets done watching the Dog Show on Animal Planet tonight :D
Sounds like your AM-21 is finding the "Physical " channel and then mapping it to the channel where you would expect to see it.
This process happens all the time , but normally it happens quickly so it isn't noticed.
Jimbo
im gonna skip this one as im waiting for replacement hr20, i believe i have a bad tuner 2 or many bad bbc's i hope, otherwise its my wiring but every other device in my abode functions as it should
HR20-700
My Caller Id appears to have stopped working after this CE.
It worked perfectly for the last month or two and now it does not want to work.
I think the guide seems a little slower in the last week or two as well.
Jimbo
Jimbo
It's not that. It's actually mapping it to where other channels are located. KTVD-DT broadcasts on digital 21 and is supposed to be mapped to 20-1. But I've found it on 41-1 where another channel was mapped previously. They all seem to show up on where other channels are mapped as new channel numbers do not appear in the guide.
Same problem as last weeks CE on my HR22-100 when 30secskip on SD programs is used it intermittently goes into like super slowmotion. The solution is to rewind or fast forward.
Report 20081005-2F0F
When opening Signal Strengths, the 101 Tuner 1 on my HR21-700 does not register normal signals, just 0's for the ones that are supposed to be 0. I changed to Tuner 2 and it displayed correctly, moved back to Tuner 1 and it displayed correctly.
I know my TV does not natively support 1080p, but for some reason it works and the receiver says that it is supported. This happened with the 9/19 CE as well.
Speed seems to be restored from 2 CE versions prior and overall it feels more polished for some reason. Hopefully it will keep running smoothly this week.
I experienced that as well.
I also can't get the edgecutter options to come back up after doing the search.
Some where along the line I lost my mediashare capabilities. I think it may have happened when I changed my router. My HR21-100 connects to the internet and VOD works. I used to be able to see the DTV box in my network connections, but that is also gone. Any ideas anyone? My current software is 0X286. Thanks
Still experiencing frustration with the IR remote mode on one of my HR20-700s.
This receiver uses the AV1/AV2 option.
This morning I shut off power to the boxes / hard drives for two hours, after turning them back on, my IR remote function is back. It did NOT come back after a RBR last night, and was still not working this morning before the "time-out". Hopefully it lasts :)
Diagnostic Report (after it's working again): 20081005-CB8
