I have been reading a lot of posts to try and get an understanding of the technology employed in Dishnetwork.
This is a summary of what I think is correct. Please tell me if I am off base but do so nicely. I am very fragile psychologically.
1. MPEG-2 and MPEG-4 are digital compression technologies. They are neither video formats (like NTSC or PAL) nor are they signal encoding techniques.
2. Any digital signal can use either but MPEG-2 would use more bandwidth than MPEG-4
3. In the world of Dishnetwork Locals all the signals via satellite are digital at the delivery point whether they began as a local analog or local digital signal.
4. Most TV's process the digital signal from the receiver into an analog signal for display.
5. Thus the terms "analog" and "digital" (at least in reference to locals) are useful primarily to distinguish between the two original signals.
6. The term analog means the analog-encoded signal (current NTSC television) and is used because it refers to the network signal as it is broadcast to antenna users.
7. Likewise digital signal (current DT/only game in town in a few months) refers to the digitally-encoded signal that stations broadcast to antennas.
8. The programming carried on this (digital) signal may be standard definition (SD) or high definition (HD) but it is the same signal (channel).
9. There are some specialty channels (not networks) that are entirely high definition programming but these are the exception.
10. There are not and probably won't be network feeds that are exclusively high definition. If for no other reason because an HD feed hogs the whole signal where a station can put multiple SD feeds.
11. You can watch HD programming on any receiver/TV combination but if the receiver and TV are not capable of HD, it will be downgraded to SD.
12. All of Dishnetwork's receivers can process MPEG-2. A few can handle MPEG-4.
13. The requirement for an MPEG-4 receiver on the Eastern Arc is because all of the signals will be MPEG-4 encoded at some point. It does not have anything (directly) to do with analog/SD/HD programming.
14. HD programming is more likely to be compressed via MPEG-4 for the reasons stated above but there is no technical requirement to do so.
15. If EA (or any other) programming is compressed via MPEG-4 then you need an MPEG-4-capable receiver even if you never plan to watch an HD program.
Ok, release the hounds.
