Uplink Activity Report - 11/12/2008 1:40pm - 165 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/12/2008 1:40pm - 165 changes
Uplink Comparison Range: 11/12/2008 01:02P - 11/12/2008 01:40P
Channel Additions:
501 - VODSV [176] added to Echostar6 72.7W TP 21 ConUS beam (NA)
14208 - WMVT2 [EPG] added to EchoStar7 119W TP 05 Midwest beam (NA)(Milwaukee, WI)
14209 - WMVT8 [EPG] added to EchoStar7 119W TP 05 Midwest beam (NA)(Milwaukee, WI)
14943 - KEYE2 [EPG] added to EchoStar7 119W TP 07 Texas beam (NA)(Austin, TX)
19086 - LUDIV [DATA] added to EchoStar8 77W TP 29 South ConUS beam (A)
19091 - PLYJV [DATA] added to EchoStar8 77W TP 29 South ConUS beam (A)
19097 - DGMSV [DATA] added to EchoStar8 77W TP 29 South ConUS beam (A)
19140 - TRIGC [DATA] added to EchoStar8 77W TP 21 South ConUS beam (A)
19140 - TRIGC [DATA] added to Echostar6 72.7W TP 21 ConUS beam (A)
19141 - SBCVC [DATA] added to EchoStar8 77W TP 29 South ConUS beam (A)
Channel Removals:
19205 - DD08 (A) removed from EchoStar11 110W TP 05 ConUS beam
Channel Moves:
220 - SLTV [MPEG4 SD] moved from EchoStar8 77W TP 29 South ConUS beam to EchoStar8 77W TP 12 South ConUS beam (A)
405 - TVGAM [MPEG4 SD] moved from EchoStar8 77W TP 12 South ConUS beam to EchoStar8 77W TP 29 South ConUS beam (A)
9636 - INSP [MPEG4 SD] moved from EchoStar8 77W TP 29 South ConUS beam to EchoStar8 77W TP 25 South ConUS beam (NA)
9645 - LF1 [MPEG4 SD] moved from EchoStar8 77W TP 25 South ConUS beam to EchoStar8 77W TP 29 South ConUS beam (A)
Channel Package Flag Changes:
103 - ONPPV [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
137 - QVC [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
149 - FSC [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
157 - OVATN [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
159 - SITV [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
177 - NICKG [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
194 - GREEN [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
196 - CURNT [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
210 - CSPAN [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
212 - CSPN2 [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
213 - NASA [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
216 - C&T [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
217 - DISH [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
218 - TJC [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
219 - ALIVE [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
221 - LSHOP [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
223(85) - SRN [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
224 - SHOP [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
226 - GEMTV [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
227(86) - JTV [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
228 - SHNBC [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
229 - GEMS [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
254 - CW [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available (H)
262 - ANGEL [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
265 - CCTV9 [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
266 - ANGL2 [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
299 - REELZ [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
400 - TENIS [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
404 - HRTV [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
502 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
503 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
504 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
505 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
506 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
507 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
508 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
509 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
510 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
511 - PPV [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
512 - PPV [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
513 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
514 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
515 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
516 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
517 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
518 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
519 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
520 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
521 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
522 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
523 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
524 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
525 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
526 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
527 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
528 - PPV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available
529 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
530 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
532 - PPV [MPEG4 SD] - EchoStar8 77W TP 21 South ConUS beam changed to Available
533 - $1.99 [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
575 - SAB [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed to Available
600 - RAI [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available
749 - RKINO [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to Available
838 - MUN2 [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available
884 - CCTVE [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available
923 - AUD01 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
924 - AUD02 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
925 - AUD03 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
926 - AUD04 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
927 - AUD05 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
928 - AUD06 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
929 - AUD07 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
930 - AUD08 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
931 - AUD09 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
933 - AUD10 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
934 - AUD11 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
935 - AUD12 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
936 - AUD13 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
937 - AUD14 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
938 - AUD15 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
939 - AUD16 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
944 - AUD17 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
945 - AUD18 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
946 - AUD19 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
950 - CD 1 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
951 - CD 2 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
952 - CD 3 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
953 - CD 4 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
954 - CD 5 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
955 - CD 6 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
956 - CD 7 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
957 - CD 8 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
958 - CD 9 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
959 - CD 10 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
960 - CD 11 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
961 - CD 12 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
962 - CD 13 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
963 - CD 14 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
964 - CD 15 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
965 - CD 16 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
966 - CD 17 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
967 - CD 18 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
968 - CD 19 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
969 - CD 20 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
970 - CD 21 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
971 - CD 22 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
972 - CD 23 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
973 - CD 24 [MPEG AUDIO] - EchoStar8 77W TP 25 South ConUS beam changed to Available
974 - CD 25 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
975 - CD 26 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
976 - CD 27 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
977 - CD 28 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
978 - CD 29 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
979 - CD 30 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
980 - CD 31 [MPEG AUDIO] - EchoStar8 77W TP 12 South ConUS beam changed to Available
981 - CD 32 [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available
983 - KDMSC [MPEG AUDIO] - EchoStar8 77W TP 29 South ConUS beam changed to Available (H)
988 - DISH6 [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available (H)
999 - RTLR [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
5774 - IAD5 [174] - EchoStar8 77W TP 29 South ConUS beam changed package flags (A)
5778 - IAD9 [174] - EchoStar8 77W TP 29 South ConUS beam changed package flags (A)
6377(9) - KMBC [MPEG4 HD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
6378(5) - KCTV [MPEG4 HD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
6379(41) - KSHB [MPEG4 HD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
6380(4) - WDAF [MPEG4 HD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
8434(62) - KSMO [MPEG4 SD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
8435(29) - KCWE [MPEG4 SD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
8436(19) - KCPT [MPEG4 SD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Kansas City, MO)
8437(38) - KMCI [MPEG4 SD] - Echostar12 61.5W TP 09 Area 8 beam changed to Available (H)(Lawrence, KS)
9395 - ANGL2 [MPEG4 SD] - EchoStar8 77W TP 29 South ConUS beam changed to Available (H)
9396 - COLRS [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9397 - BYUTV [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9400 - RSRCH [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available (H)
9401 - HITN [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
9403 - BYUTV [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9404 - UWTV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available (H)
9407 - COLRS [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9410 - LINK [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9411 - NAUHS [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
9412 - UCTV [MPEG4 SD] - EchoStar8 77W TP 16 South ConUS beam changed to Available (H)
9414 - V-ME [MPEG4 SD] - EchoStar8 77W TP 25 South ConUS beam changed to Available (H)
9415 - FSTV [MPEG4 SD] - EchoStar8 77W TP 12 South ConUS beam changed to Available (H)
19040 - ITVG [174] - EchoStar8 77W TP 29 South ConUS beam changed to Available (H)
19052 - ITVGV [174] - EchoStar8 77W TP 29 South ConUS beam changed package flags (A)
Channel Type Changes:
5747 - STVOD EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A) (H)
19063 - TVENT EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A)
19070 - HORO EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A)
19087 - LUDI2 EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A)
19090 - PLYJ EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A)
19098 - DGAMS EchoStar8 77W TP 29 South ConUS beam changed from 174 to DATA (A)
Channels in the system: 5893
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
more EA stuff?
what are these:
19086 - LUDIV [DATA] added to EchoStar4 77W TP 29 South ConUS beam (A)
19091 - PLYJV [DATA] added to EchoStar4 77W TP 29 South ConUS beam (A)
19097 - DGMSV [DATA] added to EchoStar4 77W TP 29 South ConUS beam (A)
19140 - TRIGC [DATA] added to EchoStar4 77W TP 21 South ConUS beam (A)
19141 - SBCVC [DATA] added to EchoStar4 77W TP 29 South ConUS beam (A
sigh, well Kansas City... enjoy your new HD LiL's
Those HD locals are not new. Kansas City was already getting them via the bird at 129°.
That and a bunch of MPEG-4 SD garbage sent up to 77W amounts to yet another very uneventful up-link.
As Bobby H said, KC has been getting HD LIL's for awhile from 129. This is interesting, though, since KC had not been announced as a new (activated) Eastern Arc city yet. I'm really crossing my fingers that KC will stay on Western Arc (also) after Ciel 2 is in place, since I don't have good LOS for 72 or 77.
Brad
Because we like to have full disclosure, and the techies that look at signal strength etc like to know which bird it's coming from to piece together what's happening when things go wrong.
Actually, you can't get the separation by any technical way if that slot occupied by sat cluster.
Only FCC papers could reveal what sat(s) sits there today and what tpn lite-on on particular sat in the cluster.
D
Uplink Activity Report - 11/12/2008 6:02pm - 124 changes
D
Uplink Activity Report - 11/13/2008 4:02pm - 15 changes
