Can I use a SW-21X to add 61.5 to 110/118.7 ?
f13dfx
65
I'm using a modified setup with an 33" eliptical dish to get 110 and 118.7 combined via SW-21. Can I add 61.5 with the use of a SW-21X. And which sats would I connect with the SW-21X?
I am using this setup on a 622 HD-PVR. I've had it with 129, so it isn't an option.
Thanks to those who reply.
Legacy uses SW21 (and SW64) not (Dish Pro) DP21 switches. Different switching methods. You should know that Boba.
-Ken
Apologies, OP does have Legacy. -K
Okay, for the most part the following has been working since December:
110 & 61.5 connected via SW-21X
output from SW-21X & 118 connected via SW-21
output from SW-21 connected to 622 receiver
I just have one nagging problem in that the Detroit network Conus feeds (6459 to 6462) seem to only work intermittently. Sometimes when I tune to any of these channels I get the "acquiring satellite signal" message which then gives me the following message:
"Sorry for the interruption. There is no need to call us. We are working to have this channel back as soon as possible. You may still watch non-local programming by pressing the GUIDE button on your remote control and selecting another channel."
It's kind of a puzzle and I don't know what else to try at this point. Should I try using different satellite combinations when using the SW-21 and SW-21X switches?
Your help would be greatly appreciated!
Will this Linksys Powerline PLTK300 work with a 722?
Archos recorder
