HR2x / R22 CE Release 3/13 0x02E7
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,031
436
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700 • HR21Pro
HR22-100 • HR22-200 • R22-100 • R22-200
HR23-700
Version: 0x02E7
Window of opportunity to download:
Friday, March 13, 2009 11:00PM - 2:30AM ET
Saturday, March 14, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
  • Items from CE:19:01 Moderate Risk
  • Items from CE:19:02 Moderate Risk
  • Items from CE:19:03 Moderate Risk
  • Items from CE:19:04 Moderate Risk
  • Items from CE:19:05 Moderate Risk
  • Items from CE:19:06 Moderate Risk
New features
  • 02 - New System Test and Info Screen
  • 02 - {FORMAT} button enabled while playing 1080p content
Improved/Updated
  • 01 - Recording robustness
  • 01 - Support for more actors in programs
  • 01 - Video issues playing back 1080p content at lower resolutions.
  • 01 - Audio drops/out of synch after using trickplay and jumping to bookmarks on MPEG4 HD channels.
  • 01 - Mediashare:
    • Issues with only 1 photo in the photo playlist.
    • Incorrect duration for large audio files.
    • Other Mediashare fixes/tweaks.
  • 01 - Misc. UI fixes/tweaks
  • 01 - XM channels:
    • Loss of background image
    • No music info when exiting screensaver
  • 02 - Corrected missing HD icon in My Playlist
  • 02 - Improved HD icon with manual recordings
  • 02 - Improved consecutive channel ups
  • 02 - MediaShare: Fixed aspect ratio
  • 02 - MediaShare: Improved Trick Play bar
  • 02 - Improved stability with interactive channels
  • 03 - Fixed occasional searching for satellite signal when tuning HR20-700
  • 03 - Fixed video freeze up when using Trick Play HR20-700
  • 03 - Fixed loss of background when using Interactive Applications
  • 03 - Improved Interrupted Manual Recording Display
  • 04 - MediaShare:
    • 04 - Lockups when viewing pictures.
    • 04 - Lockups when viewing streaming video.
    • 04 - Aspect ratio changes when streaming video.
  • 04 - Set Top Box tunes to channel 201 after software download.
  • 04 - Audio Synching on HD recordings after jumping to bookmarks.
  • 04 - Parental Control lock causing DOD Homepage viewing issues.
  • 04 - DOD program search program info takes you to wrong screen.
  • 04 - “Sluggish” UI behavior – especially in DOD navigation.
  • 04 - QuickMenu/On Demand addition options added.
  • 04 - Added remote codes.
  • 05 - MediaShare: Improved display for songs/titles
  • 05 - Fixed Blue flash when performing Trick Play on live TV
  • 05 - Fixed Keep at Most setting
  • 05 - OSD improvements for PPV
  • 05 - OSD improvements for deleting in To Do List
    [*]06 - Searching for satellite signal HR21-700
    [*]06 - System Test Issues
    • Does not complete
    • Dish Pointing Failure
    [*]06 - Single Frame Forwarding
    [*]06 - Updated MediaShare failing when accessing pictures and music
    [*]06 - Loss of Video when switching to HDMI
    [*]06 - Interactive Applications
    [*]06 - Loss of background when accessing Widgets
    [*]06 - Improved on screen display for pay-per-view
    [*]06 - Additional System Test improvements
    [*]06 - 1080p on screen display
Notes
  • You will lose you guide cache when going between national and this release
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
  • Please make sure to first attempt to tune to an OTA channel before running an OTA signal strength system test
    [*]06 - Widget Keyword will be reset - Do a search for WIDGETSON to re-enable
Please note this CE will disable widgets, you will have to redo the keyword search WIDGETSON to re-enable them.
Also, the widget site received a facelift this weekend, and more users may be able to access widgets for their receivers now. Please see the widget thread for info on the site. We've been asked to delay until Monday to use the widget site.
http://www.satelliteguys.us/directv...um/163002-widget-testing-ce-02-04-1-28-a.html
I mentioned in previous CE threads that I was getting an audio crackle/pop between switching channels with my HR22-100 and Samsung 40inch LCD. This new CE version seems to have corrected that issue.
Issues:
When show is paused and Screen Saver is on, the screen saver flashes to the regular screen of that paused show and then back to the screen saver. Happen after in screen saver for a few min, and occurs every min or so.
Switching between live tv from pre-recorded show is very slow and sluggish. Channel changing speed on live tv is faster, but still slow.
Widgets will not show up when pressing the right arrow button like it used too. I redid the "widgetson" keyword and still doesn't work. It doesn't make the bonk noise like I hit the wrong button. The light on the receiver flashes like it recognized it, but screen doesn't appear. Noticed the same problem on last CE also.
When hitting play on a recorded show when it was on paused, the picture doesn't start with sounds. The picture is still frozen, but the sound is playing and then it works correctly.
Slow response time when getting a pre-recorded show to play from the list. The first initial playing on a recorded show is slow on response time.
Guide and Menu looks Grainy and not crystal clear like it used to and should
Suggestion: Quicktune feature should display what is playing on the highlighted channel.
Issues:
FWIW, I've had this issue for a while and I'm on the national release.
Searched for keyword WIDGETSON to reactivate widgets. Now, just like last week's CE, widgets don't come up with the right arrow, and after I try, any full-screen menu (guide, setup, etc.) has a black background instead of the D* graphics.
Sent report 20090316-1F79.
network services stopped working has been flawless for months now no changes to network at all and i have even tried to put it in a dmz but no go so i am unable to login to gamelounge with out phone line now
