CE Release for H21/H23 5/22 v.42EB
Rey
@ your service
27,003
585
Florida
Current Window of Opportunity:
Friday, May 22, 2009 11PM - 2:30AM ET
Saturday, May 23, 2009 11PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
H21-100, H21-200, H23-600 (x42EB)
Areas of Focus
• Under the hood
Notes
• H21-100: customer candidate
• H21-200: customer candidate
• H23-600: customer candidate
• Going back to National will go back to default settings and lose local market ID setting
• Please report non-MRV issues only
Previous Release Notes:
New features
01 - Network
01 - Media Share
01 - Music Screen Saver
01 - Game Search
01 - 1080p/24
01 - OTA via the AM21
01 - Autotune
01 - Multi-Room Viewing
:::::::View Playlist from a networked HR2x or R22
:::::::playback/Trick Play functions from any networked HR2x or R22
:::::::press {LIST} to see HR2x or R22 servers one playback per server at a time
02 - Parental Controls when scheduling autotune
02 - MRV: bookmarks and resume playback from previous location
04 - Friendly name in network setup
04 - QuickTune
05 - Built-in Self Test
13 - Advance setup in remote control
Improved/Updated
02 - Support for more 1080p Sony TV models
02 - Faster Guide scrolling
02 - ATSC signal meter performance
02 - Fixed a screen saver issue
02 - ATSC setup screen now works on first boot
02 - Fixed reappearance of deleted autotunes
02 - UI updates ("tuner 2" and "tuner 3" references)
02 - Fixed Gray Screen or a PPV OSD appearing overnight
02 - Improved "Try Again" when trying to connect to the Internet.
03 - AV1/AV2 remote code refinements
03 - Improvements to DHCP network setup
04 - Issues with rebooting while in standby
04 - WGA600N Support
04 - Static IP Setup
05 - Stability
05 - Missing “Just a few seconds” OSD
05 - MRV playback and trickplay problems
05 - User Interface polishing
06 - Network services, Network setup, Network status
06 - One touch autotune via Enter key
06 - H21-100, SWM compatibility--will not affect other boxes
06 - H21-100, remote control support
06 - Removed “Reformatting Hard Drive" screen after Reset Everything
06 - Changing Display Language
07 - One touch autotune via Enter key
07 - WGA600N setup with WPA encryption
07 - Receiver not resetting
07 - Closed Captioning Loss
08 - Autotune on ATSC channels
08 - WGA600N setup with WPA encryption
08 - UI Improvements
08 - Missing spending limit unlock OSD
08 - SWM issue, Signal Strength H21-100
08 - System test H21-100
09 - Network Setup
09 - Autotune on ATSC channels
09 - Keyword search
09 - Screen flash coming out of Standby
10 - Improved Front Panel display on boot up
10 - IR Remote H21-100
10 - Remote setting when reset defaults
11 - PPV spending limit conversion (compared to national release)
11 - Video when switching to alternate audio
11 - Fixed blank reset everything screen
12 - Stability fixes
12 - Faster keyword search
12 - Reset everything warning message
13 - Autotuning when using parental controls
13 - Fixed "tune to 201" issue
13 - Reset defaults correctly sets the hide/show SD duplicates option
13 - Updated connection successful message in Network setup
13 - Stability
14 - Autotune Fixes:
::::::Manual with past start times
::::::Lingering icon after canceling
::::::parental Controls
::::::Minor polishing
14 - Updated welcome screen and help messages
15 - Autotune Scheduling with Viewing Hours set
15 - Preserve favorites when converting from NDS to DIRECTV firmware
15 - HDCP content protection H23-600
15 - Minor polishing
16 - Additional improvements to items from previous CE
17 - Scheduling autotunes
17 - Resetting the set-top-box in standby
17 - Call ID inconsistency
18 - Scheduling autotunes
18 - Coming out of standby
19 - Showings in Info Screen
19 - PPV autotunes when converting to new Middleware
20 - Improved tuning stability
FrankoQ
39
MD
Some help please.
I did the CE. it did a download but it currently has 0x4086
I do not see the "Miscellaneous Options"
After the CE is done, what do I do to hook up the wireless adapter to hook it up to my home wireless network?
Then, I hope to be able to MRV from the HR-22 box.
Please help. I searched but cannot find clear answers.
FrankoQ
39
MD
Franko - if your version is 4086 I'm guessing you didn't successfully download the CE.
Try reading over the how-to in this thread. You can try the download again tonight at 11pm ET.
http://www.satelliteguys.us/directv...ogram-terms-faq-how-hidden-features-more.html
Thanks for the link. Doh! I didn't read it well and thought the downloads were automatic. Instead, we have to force them... just as stated.
I did the download on my 2 boxes last night.
The HR-22 is connected to the home network.
The H-23 is my headache.
After the CE download, I can now see the options menu and the network options. I still cannot get that box on my network using a wireless adapter.
I have the linksys WGA54G.
Any other tips to make this work?
I ran the config on the device
now connected it to the h 23 box.
when I do the connect now,
I get:
IP - ok
subnet mask - OK
default gateway - OK
DNS - OK
Network - Connected
Internet - not connected to the internet (22)
Any ideas?
FrankoQ
39
MD
I get:
IP - ok
subnet mask - OK
DNS - OK
Network - Connected
Any ideas?
I got it to work. It's a problem with my wep settings.
If I remove wep from the router, the game adapter connects fine.
I now need to look into that to get wep back on.
FrankoQ
39
MD
Sounds like the WEP key isnt the same as the one on the router.
The keys were the same.
It seems every time I make a change on the wireless adapter, I have to
unplug it and plug it back on. weird but working now with WEP enabled.
Rey
@ your service
27,003
585
Florida
DK:20090527-1BC5
H21-200
This CE has been very solid. no issues at all that i'm aware of including MRV. good job D :up:up
