DISH HD WISH LIST: AMCHD, TCMHD, CCSN-ChicagoHD fulltime, G4HD, MLBTVHD, OutermaxHD, ESPNUHD, SPROUT & MLB Extra Innings PLEASE!
The image below shows a number of average HD video bitrates from the past few weeks. All programming is HD (nothing being upscaled). 12 different channels are represented across 3 satellites: 61.5W, 72.7W, and 110W. All samples were at least 60 minutes in duration.
As HDRoberts mentioned, the bitrate is going to vary under different conditions. I wouldn't say that 5-6 Mbps is common anymore, but it does still happen under some conditions.
You're looking at transponders supporting about 41 Mbps typically having at least 8 HD channels for the satellites shown above. Subtract about 3 Mbps for 8x 384 Kbps audio streams, plus say 1 Mbps for the NULL stream (although it can be quite a bit higher on average on some transponders), plus another 1 Mbps for the normal data streams and you have 36 Mbps left. With that, you're averaging about 4.5 Mbps video per channel with 8 channels/transponder, about 4 Mbps with 9 channels, and 3.6 Mbps with 10 channels (or 9 channels plus a bunch of extra data streams, like transponder 32 on 61.5W).
Nope not tomorrow.I think we will see the new channels tomorrow.
Nope not tomorrow.
Are you ready for a MONDAY uplink?
I think DISH uses 24 Mhz wide transponders and with DVB-S2 and 8PSK they should be getting around a MUX Rate 51 Mbps.
Smith.P measured a MUX rate ~50Mbps
http://www.satelliteguys.us/attachment.php?attachmentid=40191&d=1248797069
Dish runs variable bit rate encoders, so it is tough to tell, but 5-7 Mbps is common. The bit rate is also dependent on what else is going on in the transponder. If one channel doesn't need the space, another channel can borrow the space.
Are you saying that they dynamically re-encode the video based on the currently running programming? Is that something they do in real (or near real) time? That would surprise me although I guess H264 encoding is getting faster. Or do they just prepare their encoding ahead of time based on the schedule so it all comes out just right when aired? Of course that wouldn't work for live programming.
It is active and does this in "real time". The encoders they use have links between them that "follow" each others use of bits. So a talking head show will get a lot less than say a fast action section of a football game. I had hands on some of the encoders just after E* & D* had ordered a large number of them. In fact that was one of the selling points the engineer and sales agents used in their pitch (yes there were both there). The reaction times between a linked set of encoders for shifting the bits is nanoseconds. So the delay is "near real time". They also use what is know as predictive adaption in "pre-sampling" the video. The encoders are very sophisticated devices. And what mike said.
Ask DigiBlur, he can pull up the bitrate of channels on a transponder or give you an idea where they are running at, but remember that MPEG 4 channels will be much lower than Mpeg 2 HD channels as the compress alot better and retain the same information for the most part.
Motorola DVB-S2 and 8PSK field trials: The first is using the advanced modulation techniques offered by the newer DVB-S2 8PSK satellite transmission standard that allows as much as twice the amount of bits to be sent over existing 36 MHz transponders. With this technology, programmers can deliver up to 77Mbps over the same transponder that is currently delivering 40 Mbps.
http://www.motorola.com/staticfiles/Business/Solutions/Industry%20Solutions/Service%20Providers/Broadcasters%20and%20Programmers/_Documents/Programmer_Distribution_Trends.pdf?localeId=33
77Mbps@36Mhz scales to 51Mbps@24Mhz
