1/19/2011 2:43pm - Uplink Activity Report - 112 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/19/2011 2:43pm - 112 changes
Uplink Comparison Range: 01/19/2011 02:29P - 01/19/2011 02:43P
Channel Additions:
5194(13) - WNYA [MPEG4 HD] added to Echostar12 61.5W TP 03 Spotbeam 3 (Mkt:Albany, NY-Pittsfield, MA-MY) (NA)
9135(5) - WNGS [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 09 (Mkt:Buffalo, NY-Springville, NY-RTN) (NA)
9135(5) - WNGS [MPEG4 SD] added to Echostar12 61.5W TP 13 Spotbeam 4 (Mkt:Buffalo, NY-Springville, NY-RTN) (NA)
8259(33) - NVUE [MPEG2 SD] added to EchoStar14 119W TP 04 Spotbeam B11 (Mkt:Austin, TX) (NA)
8879(9) - KTRE [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 15 (Mkt:Tyler, TX-Lufkin, TX-ABC) (NA)
240 - HUNT [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS beam (NA)
596 - CDYTV [MPEG2 SD] added to Anik F3 118.7W TP 15 ConUS beam (NA)
998 - TEST1 [182] added to Anik F3 118.7W TP 32 ConUS beam (NA)
4858 - INVV9 [MPEG4 SD] added to Anik F3 118.7W TP 32 ConUS beam (NA)
4891 - TMP1A [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4892 - TMP1C [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4893 - TMP1N [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4894 - TMP1F [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4895 - TMP2A [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4896 - TMP2C [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4897 - TMP2N [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
4898 - TMP2F [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
9472 - TMP E [MPEG4 HD] added to Nimiq5 72.7W TP 16 ConUS beam (NA)
14951 - WCBB3 [EPG] added to EchoStar10 110W TP 23 Spotbeam 08 (OTA EPG:Augusta, ME)(NA)
Channel Removals:
240 - INFO (NA) [MPEG2 SD] removed from EchoStar14 119W TP 09 ConUS beam (Dish Network Information Channel)
826 - CDLAT (A) (FP) [MPEG AUDIO] removed from EchoStar14 119W TP 08 ConUS beam
826 - CDLAT (A) (FP) [MPEG AUDIO] removed from Nimiq5 72.7W TP 25 ConUS beam
4137 - TMP37 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
4137 - TMP37 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 32 ConUS beam
4142 - TMP23 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 28 ConUS beam
4142 - TMP23 (NA) [MPEG4 HD] removed from EchoStar15 61.5W TP 25 ConUS beam
4153 - TMP63 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam
4153 - TMP63 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 03 ConUS beam
4174 - TMP22 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 27 ConUS beam
4174 - TMP22 (NA) [MPEG4 HD] removed from EchoStar15 61.5W TP 25 ConUS beam
5316 - TMP37 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
5316 - TMP37 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 32 ConUS beam
6800 - UP4 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 01 Spotbeam B22 (Virtual Channel)
6800 - UP4 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 13 Spotbeam 17 (Virtual Channel)
6800 - UP4 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 18 ConUS beam (Virtual Channel)
6801 - UPSD (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 11 ConUS beam (Virtual Channel)
6801 - UPSD (NA) [MPEG2 SD] removed from EchoStar14 119W TP 04 Spotbeam B9 (Virtual Channel)
6802 - UP2 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 02 Spotbeam A28 (Virtual Channel)
6803 - UP3 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 21 ConUS beam (Virtual Channel)
6803 - UP3 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 04 Spotbeam A28 (Virtual Channel)
6804 - UP7 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 04 ConUS beam (Virtual Channel)
6805 - UP4 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 05 ConUS beam (Virtual Channel)
6806 - UP8 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 08 ConUS beam (Virtual Channel)
6806 - UP8 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A27 (Virtual Channel)
6807 - UP10 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 09 ConUS beam (Virtual Channel)
6807 - UP10 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 03 Spotbeam A27 (Virtual Channel)
6808 - UP9 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 10 ConUS beam (Virtual Channel)
6808 - UP9 (NA) [MPEG2 SD] removed from Echostar12 61.5W TP 01 Spotbeam 14 (Virtual Channel)
6810 - UP4 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 14 ConUS beam (Virtual Channel)
6810 - UP4 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 04 Spotbeam B23 (Virtual Channel)
6811 - UP4 (NA) [MPEG2 SD] removed from Ciel-2 129W TP 20 ConUS beam (Virtual Channel)
6812 - UP4 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 07 ConUS beam (Virtual Channel)
6813 - UP4 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 02 Spotbeam A25 (Virtual Channel)
6814 - UP4 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 03 Spotbeam A24 (Virtual Channel)
6815 - UP5 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 04 Spotbeam A25 (Virtual Channel)
6816 - UP5 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 05 Spotbeam A24 (Virtual Channel)
6822 - UP5 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam (Virtual Channel)
6826 - UP6 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 03 Spotbeam B22 (Virtual Channel)
6826 - UP6 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 16 ConUS beam (Virtual Channel)
6828 - UP6 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 02 Spotbeam A8 (Virtual Channel)
6834 - UP7 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 28 ConUS beam (Virtual Channel)
6840 - UP8 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 08 Spotbeam 29 (Virtual Channel)
6841 - UP29 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 32 ConUS beam (Virtual Channel)
6846 - UP11 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 02 Spotbeam A18 (Virtual Channel)
6846 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 12 ConUS beam (Virtual Channel)
6847 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 16 ConUS beam (Virtual Channel)
6848 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 21 ConUS beam (Virtual Channel)
6849 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 03 Spotbeam 14 (Virtual Channel)
6850 - UP9 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 03 Spotbeam B2 (Virtual Channel)
6850 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 05 Spotbeam 15 (Virtual Channel)
6851 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 07 Spotbeam 14 (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 01 Spotbeam A13 (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 09 Spotbeam 14 (Virtual Channel)
6853 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 11 Spotbeam 15 (Virtual Channel)
6854 - UP9 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 03 Spotbeam B10 (Virtual Channel)
6854 - UP9 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 13 Spotbeam 15 (Virtual Channel)
6855 - UP10 (NA) [MPEG4 HD] removed from Echostar12 61.5W TP 15 Spotbeam 14 (Virtual Channel)
6855 - UP10 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 32 ConUS beam (Virtual Channel)
6861 - UP29 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 02 Spotbeam 54 (Virtual Channel)
6863 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 01 Spotbeam A7 (Virtual Channel)
6870 - UP29 (NA) [MPEG4 HD] removed from Echostar15 61.5W TP 23 ConUS beam (Virtual Channel)
6880 - UP11 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 03 Spotbeam A17 (Virtual Channel)
6880 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 25 ConUS beam (Virtual Channel)
6884 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 28 ConUS beam (Virtual Channel)
6888 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 02 Spotbeam B8 (Virtual Channel)
6894 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 04 Spotbeam B14 (Virtual Channel)
6897 - UP29 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 16 Spotbeam 55 (Virtual Channel)
6915 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 02 Spotbeam A14 (Virtual Channel)
6945 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 02 Spotbeam A16 (Virtual Channel)
Channel Moves:
73 - WLS [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Chicago, IL)(A) (H)
74 - WBBM [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Chicago, IL)(A) (H)
75 - WMAQ [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Chicago, IL)(A) (H)
76 - WFLD [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Chicago, IL)(A) (H)
77 - KABC [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
78 - KCBS [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
79 - KNBC [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
80 - KTTV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 21 ConUS beam (Los Angeles, CA)(A) (H)
573 - SNSKR [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (NA)
586 - ALPHA [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to Echostar15 61.5W TP 21 ConUS beam (A) (H)
597 - TVBSL [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
648 - ASTHA [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to Echostar15 61.5W TP 21 ConUS beam (NA)
649 - ZOOM [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A) (FP)
652 - TIMES [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (A) (FP)
739 - BENFC [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to Echostar15 61.5W TP 21 ConUS beam (NA)
767 - RELIG [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to Echostar15 61.5W TP 21 ConUS beam (A) (H)
776 - MTVH [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (NA)
798 - SAMAY [MPEG2 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Sahara Samay Rashtriya (Hindi)) (NA)
6809 - UP4 [SD TV] moved from Anik F3 118.7W TP 12 ConUS beam to EchoStar15 61.5W TP 06 ConUS beam (Virtual Channel) (NA)
Channel Package Flag Changes:
586 - ALPHA [MPEG2 SD] - Anik F3 118.7W TP 08 ConUS beam removed from free preview (A)
807 - TV9 [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam removed from free preview (A) (TV 9 News (Gujurat ))
Channel Renames:
9400 - RSRCH (Research Channel) - EchoStar11 110W TP 03 ConUS beam renamed to BABY1 (NA)
9400 - RSRCH (Research Channel) - Nimiq5 72.7W TP 11 ConUS beam renamed to BABY1 (NA)
Channels in the system: 7524
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
Well, I guess no hope of getting ESPNNews HD(142) or Disney XD Hd(174) back anytime soon... Also, sayonara to QVC HD(137), not that I really care - but what was 4153? There is no 153 SD channel....
Are these going to be New HD Channels?
Why do you say that digiblur? I know they were supposed to be removed on the 12th, but this just moved them to another ConUS beam no?
It's known that they were going away today. Some already lost them before today. The moved them to a QPSK (non-HD) transponder so that means they are pointing to slate. This was also confirmed by a member that still had his channels showing today.
Look at the letters.. A=ABC, C=CBS, N=NBC, F=FOX. Two things... either they placed them there to still keep the old video streams up for the distant HD locals to keep them encrypted, since a lot of time orphaned video streams are not encrypted. Or or... holders for something else coming with those same call letters in HD? ;)
They also have guide data. ;)
I wonder which group of waivers they will want? Dish, AAD or the grandfather we had before. Or maybe a whole new set!
Interesting. We already have an ABC affiliate (KLTV) on DISH. KTRE is basically a copy of KLTV. Just what we need!
well it could be one of two channels
-Telemundo (subchannel)
-or possibly the 2ndf ABC. Since they are a semi-satellite it is possible Dish can carry both affiliates. They dont have to (unless the affiliates are in the same DMA but different states) but there are a couple of these out there...most notably WDAY in Fargo and WDAZ in Grand Forks (same market)..
Wiki says it was to be added "soon"...well 9 months or so ;)
In June of 2010 the station reported it would soon be on DISH Network. The station is said to release a air date soon.
Glad to see Dish has added pursuit tv on channel 240. Although it is listed as not available, it is on right now. For those that like the outdoor type programming, this is a great addition.
By the way, whatever happened to the Outdoor Channel going HD? They advertise on their channel that all content is available in 100% HD. Just wondering why dish has yet to go HD on this channel.
D
1/20/2011 4:28pm - Uplink Activity Report - 8 changes
D
1/24/2011 12:54pm - Uplink Activity Report - 2 changes
